11-21-2014, 06:38 AM | #1 |
Rock Stacker Join Date: Feb 2013 Location: Concord, NC
| Lowering CG and Suspension Questions
I have a Wraith kit that is basically stock. I've noticed that I need to lower the center of gravity since it has a tendency to tip over while turning at higher speeds. I've got it set up more as a trail runner/basher than a strict rock crawler. I'm going to do the front mounted battery mod and that will help but I was also looking into lowering it a bit. Is the droop kit recommended or would shorter shocks do the same trick? I'm running the stock Axial shocks but with the Axial aluminum shock bodies. I've tried searching but can't find a write up on the droop kit.
11-21-2014, 06:57 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: Lowering CG and Suspension Questions |
11-21-2014, 07:01 AM | #3 |
Thanks wiz, do you run stock length shocks? I can't see them in the pic
11-21-2014, 07:08 AM | #4 |
Yeah. Just the bog standard that came with it. I like the lower links to be almost parallel to the chassis. The Level 3 kit allows for many options to suit all though. |
11-21-2014, 07:21 AM | #5 |
Cool, I saw someone mention flipping the shock mounts. Do you need to do that with the droop kit?
11-21-2014, 07:27 AM | #6 |
Mine are still flipped from prior to adding the kit. Personally I would not. They are at a more obstructive angle when flipped. Should really put mine back!
11-21-2014, 07:38 AM | #7 |
Ok thanks a lot wiz! I appreciate the help
11-21-2014, 07:52 AM | #8 |
Did you do the panhard conversion too?
11-21-2014, 08:17 AM | #9 |
On a Wraith I had a few years ago I had the VP panhard. I must admit I never liked the panhard setup. I prefer the on axle servo as it just works better IMO.
11-21-2014, 08:47 AM | #10 |
Duly noted
11-21-2014, 07:29 PM | #11 |
Rock Crawler Join Date: Nov 2013 Location: In the country
Flip shock mounts and move battery up front asap. You will see extremely better results. I'm also lowering mine more as well. But that free mod was a huge difference. In have pan hard and wont go back but might not have gotten if known better prior.
11-22-2014, 03:15 AM | #12 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
I run Level3 kit with Traxxas Bigbores XXL and Axial purple springs, 30wt oil and linkmounts not flipped. Couldn't be happier. Sits as low as I want, links paralell with the skid. For the price nothing beats the Bigbores. Very good and durable shocks. I also recommend moving the battery up front.
11-22-2014, 08:02 AM | #13 |
Thanks for the replies jwall and Odd-M! I'm definitely moving the battery up front and I put in an order for the Level 3 kit. I think I'm going to stick with the stock shocks for now and see how that works. I'm still not sure about the mounts but I think I'm going to leave them alone for now.
11-22-2014, 09:26 PM | #14 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
I flipped the shock mounts along with using scx10 shocks. Even better yet...
11-24-2014, 08:18 AM | #15 |
Does anyone run knuckle weights?
11-24-2014, 12:35 PM | #16 |
On a related note, does anyone know if the AX30111 Axial Aluminum Shock Cap are compatible with the AX30120 Axial Aluminum Shock body 12x47.5mm? In the compatibility section on the Axial site it lists the Wraith kit. I'm assuming that they are compatible since the aluminum shock bodies replaces the stock plastic ones.
Lowering CG and Suspension Questions - Similar Threads | ||||
Wraith 'Dialed in' suspension lowering kit! | douglastee | Videos! | 0 | 11-07-2012 07:25 AM |
Quick wraith suspension lowering | Pateskiee | Axial Wraith | 3 | 04-14-2012 02:42 PM |
Lowering the suspension for the sake of looks | spacephrawg | Axial SCX-10 | 17 | 03-13-2010 10:45 AM |
Tundra chassis questions - lowering and drop bed | mrklaw | 1.9 Scale Rigs | 2 | 08-13-2009 10:13 AM |
suspension questions | sabo_traxxas | Traxxas Crawlers | 4 | 02-05-2008 12:04 PM |
