11-23-2014, 10:13 PM | #1 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Vanquish products issue.....
I bought these: 12mm Hex Black - Vanquish Products So I could use these: KMC Enduro 2.2 Wheels Black - Vanquish Products But they fit these: Wraith VVD V1-HD 4mm Stubs - Vanquish Products And I need them to fit these: Vanquish VVD Axial Wraith Version #2 5mm Stubs - Vanquish Products Do you guys have any suggestions, or is this one of those instances where I just have to wait for a product release, cause as it stands I pretty ticked off now that I've started assembling things. Short and sweet, I need a quality 12mm hex hub with a 5mm ID through hole for the stub axle |
11-23-2014, 11:04 PM | #2 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
| Re: Vanquish products issue.....
Drill bit will make them fit. We do it all the time.
11-24-2014, 07:58 AM | #3 |
RCC Addict Join Date: Aug 2013 Location: Missoula
"****May require drilling out 12mm hexes to clear the 5mm threads"
11-24-2014, 08:33 AM | #4 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
| Re: Vanquish products issue..... Any recommendations on doing this "square" without a drill press, I only have a drill and Cresent wrench, got one dead center, and 2 off a bit, don't want to go through a bunch for a set of 4, any tricks to get it dead nutz every time? ? Wish vp offered them in 5mm too!!!
11-24-2014, 09:11 AM | #5 | |
| Re: Vanquish products issue..... Quote:
11-24-2014, 10:01 AM | #6 |
Great info RcBro, I'll run over to the shop and switch on the drill press.
11-25-2014, 03:31 PM | #7 | |
Rock Stacker Join Date: May 2009 Location: Rossiter
I just used progressively larger bits in a drill press and kept test fitting the hexes until they were a tight fit on my 5mm stubs. One of mine was a little off-center but it still works fine. | |
Vanquish products issue..... - Similar Threads | ||||
Vanquish Products Hurtz dig shifter issue & the fix. | WIDELOAD | General Crawlers | 5 | 02-27-2016 02:29 AM |
