11-28-2014, 07:03 PM | #1 |
Rock Stacker Join Date: Sep 2014 Location: Canada
| Axial wraith questions
So I am getting a wraith spawn christmas I want to get upgrades but including the car I do not want to go over 500 so what parts will I need I also want a waterproof motor esc combo brushed and a good battery ... Liek a goood one and is lowering the suspension worth it? |
11-28-2014, 07:50 PM | #2 |
Pebble Pounder Join Date: Oct 2007 Location: Barnesville
| Re: Axial wraith questions
What are you planning on doing with your wraith crawling /bashing / mud trail ? Lowering helps with stability and less prone to tipping but reduces ground clearance. The motor that comes with the wraith isn't horrible. It's geared a little high and most recommend changing the gearing. I suggest reading the wraith sticky guide for all this info. The servo isn't the greatest I wore mine out in about 10 packs or so. The plastic in the suspension setup allows for a lot of flex / slop. It's a plus with durability because it helps absorb a lot of brutal impact. If you stay brushed 2 cell your drive shafts will last longer but go brushless /3 cell and u can hang the stock drive shafts up.
11-28-2014, 08:32 PM | #3 |
Read the stickies at the top of the section, they will answer all the questions you've been asking.
11-28-2014, 09:05 PM | #4 |
K thanks and I want to trail and crawl and mud but enwvtually I'm gonna go brushless so I won't be able to go In water but its okay
11-29-2014, 05:44 AM | #5 | |
Pebble Pounder Join Date: Jan 2014 Location: NB Canada
| Re: Axial wraith questions Quote:
I burned out the 20T that came in my wraith so I went down one tooth on the pinion ($5) and it seems to have helped a lot with motor temps. | |
Axial wraith questions - Similar Threads | ||||
Axial wraith questions | Mikael | General Crawlers | 4 | 11-29-2014 10:04 AM |
New Axial Wraith questions. | bobaloohoo | Newbie General | 7 | 08-25-2014 05:56 PM |
fun day at the (axial wraith rock race - scalers axial honcho - axial discovery) | gionata78 | Scale Videos! | 1 | 08-06-2013 11:52 AM |
Axial Wraith stock ESC questions | Robchinchilla | Axial Wraith | 2 | 01-11-2013 05:00 AM |
Wraith Questions | sullivanscx10 | Axial Wraith | 10 | 01-22-2012 09:14 AM |
