11-29-2014, 02:32 AM | #1 |
RCC Addict Join Date: Oct 2014 Location: UK
| SSD - Wraith Option Parts
Check out the new scale diff cover and D60 knuckles from SSD: Both a direct fit onto the Axial AR60 axle. Together they transform the look of the stock axle into a scale axle. More Wraith upgrades are now available from SSD: SSD Titatium Steering Links for Wraith SSD High Ratio Transmission kit for Wraith SSD Parts for Wraith Last edited by SSD; 02-19-2015 at 01:13 PM. |
12-03-2014, 02:22 PM | #2 |
Quarry Creeper Join Date: Oct 2010 Location: Nashville TN
| Re: SSD - Wraith Axle Option Parts
these look great! do the knuckles use stock bushings? if so, will Dlux no slop bushings fit?
12-04-2014, 02:28 AM | #3 |
| Re: SSD - Wraith Axle Option Parts Thanks. Yes they use all the stock bushings and hardware. Not sure about the Dlux bushings as we dont have any here to try but if they are same as stock then they should fit.
12-04-2014, 02:43 AM | #4 |
RCC Addict Join Date: Feb 2012 Location: UK
I'll be buying the diff covers once these this nasty Asiatees ones cave in. The front it already dented. |
02-19-2015, 11:10 AM | #5 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
anyone try the SSD 2.2 wheels on a wraith yet?
02-19-2015, 12:13 PM | #6 |
Updated the first post with some new additions to the SSD Wraith option parts
02-19-2015, 12:22 PM | #7 |
I really want to try that transmission conversion. If I want some more wheel speed would it be okay to use the overdrive in my front axle still? Also will it work with the vanquish motor plate and gear guard?
02-19-2015, 01:02 PM | #8 |
Yes it's fine to use any gears you want in your axles. This transmission will increase your wheel speed. It's the same as 2nd gear in the RC4WD AX2/Summit 2 speed. The stock/VP motor plate won't fit as the screws are in different locations due to the large idler gear. The stock motor cover does fit though. |
02-19-2015, 01:02 PM | #9 |
Pebble Pounder Join Date: May 2008 Location: tucson
I like the diff cover and the knuckles, when are the parts available?
02-19-2015, 01:04 PM | #10 |
| Re: SSD - Wraith Axle Option Parts |
02-19-2015, 01:18 PM | #11 |
02-19-2015, 01:32 PM | #12 |
Quarry Creeper Join Date: Feb 2006 Location: Muskegon
I saw this on RPP earlier also. On the trans, we can still use the Supershafty top shaft and outputs correct? gears have the same size bearings as stock?
02-19-2015, 02:15 PM | #13 |
Use all the same bearings. You can't use stock style outputs as the final gear is smaller. The output shaft is hardened tool grade steel anyway. Any stock top shaft fits so if the Supershafty shaft is the same spec as the stock shaft then it should fit. But we can't be sure as it's another manufacturers part. |
02-19-2015, 03:08 PM | #14 |
RCC Addict Join Date: Aug 2013 Location: Missoula
The whole transmssion is only $65 |
02-19-2015, 05:21 PM | #15 |
02-19-2015, 05:31 PM | #16 |
It's a case, gears and motor plate. It's 90% of a transmission.
02-19-2015, 09:48 PM | #17 |
Any chance of you guys making a gear guard? Something that only covers the top of the spur? Not a fan of the stock cover and I would have to cut it up to clear my battery forward plate.
02-20-2015, 10:01 AM | #18 |
02-20-2015, 01:48 PM | #19 |
Pebble Pounder Join Date: May 2010 Location: Brew City
The scale diff cover looks nice. I have a question: It appears as if the piece is aluminum, painted black. How well can the paint coat hold up on the trails? Will the paint scratch easily? |
02-20-2015, 02:17 PM | #20 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: SSD - Wraith Axle Option Parts The diff cover is anodized black aluminum, grinding against rocks will scratch the surface/finish of everything eventually.
SSD - Wraith Axle Option Parts - Similar Threads | ||||
Rear axle option | Erik D_lux | RC4WD Bully | 6 | 05-14-2015 09:26 AM |
part front& part behind the axle steering | assassin_tl | Venom Creeper | 3 | 11-03-2009 07:49 AM |
TLT Axle Mini Option | Harvo | Newbie General | 2 | 10-10-2008 04:35 PM |
