12-04-2014, 10:26 AM | #1 |
Pebble Pounder Join Date: Jan 2014 Location: home
| brushed motor question for wraith
I have done some looking and havnt really found the answer so to move my decision along alittle faster I figured I would just ask the group. so I have a poison spider wraith .. was rtr .. now has sv3 esc and I was going to run a titan 21 550 motor {what I ran in my scx10} but thinking its not the best I put the stock 20t and esc in my scx10 and it screams now .. way faster than the 21 titan{wich had 23t pinion and axial motor has stock 20t} weird I guess I let the titan sit after last water run and its junk now .. so sence I have to get a new motor any way ... what is a good motor that has same speed as stock axial 20t and more grund for the rocks .. I will be running 2 s and 3 s second .. what is better to use for all around .. 2s or 3s and yes I will switch to 32p gears . I already orderd junfac drive shafts thanks for the help in advance |
12-04-2014, 11:50 AM | #2 |
| Re: brushed motor question for wraith
The 20t motor was a poor choice out of the box, it overheats too easily and even better quality brushed motors are going to have similar results in a rig like the wraith. Honestly to keep or improve top end, you have to go brushless for good results. Otherwise, a 27t motor or the equivalent is the best bet. This can all be found in the sticky at the top of this page. |
12-04-2014, 12:02 PM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: West Alabama
I have an sv3 and an hpi 27t in mine. If you're looking for speed this is not the way to go. 27t needs too much gear to be fast. Granted its not walking pace at full throttle but its not racing speed. Definitely brushless if you want high speed and cool temps
12-04-2014, 01:28 PM | #4 |
I guess I should specify speed .. around the same speed as stock .. i do water and mud from time to time and don't want brushless because of that and what the cost would be to go waterproof brushless sensered are motors like the hh crawlmaster {79$ one ish} 20t that much better than stock .. that's at the max i want to spend but will if it will last and perform again i am looking for something around stock speed and with alittle more trq .. i looked at the sticky but couldn't find anything that described what i am looking for. i do mainly trail runs / creeks / some crawling but when i do cralw its in the middle of a trail run anyway .. never dedicated crawling thanks again |
12-04-2014, 01:52 PM | #5 | ||
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: brushed motor question for wraith Quote:
The stock 20t is misleading, it goes fast until it wears the brushes or comm out fast then they die. To get that kind of wheel speed out of a brushed motor means getting low turn brushed motors and gearing them appropriately (this is where the PIA comes in, gearing.) | ||
12-04-2014, 02:51 PM | #6 |
Quarry Creeper Join Date: Aug 2014 Location: San Diego
I have a sensored novak esc and 5000kv in my Wraith. It is plenty fast on a 2s.
12-04-2014, 02:53 PM | #7 | |
You aren't going to get the stock speed out of a brushed motor, not while having something that had good torque and is reasonably setup. The Crawlmaster Sport is $35 and works well. It's about as fast as you'll get out of a brushed motor and have good low end with decent wear. In this video I showed the comparison of the two motors. | |
12-05-2014, 03:06 PM | #8 |
13t it is ... that's what i wanted .. better than stock and around the same speed .. its a hair slower but not enough to matter
12-06-2014, 12:07 AM | #9 |
Rock Stacker Join Date: Feb 2008 Location: AL
I have had a 21t Torque Master Pro for a little over 3yrs. I've used a SC3 and Torque Master BR-XL on 2S and get good speed and very good low end grunt.
12-07-2014, 11:23 PM | #10 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
As usual Harley is right those Holmes motors are Def worth it. I have crawlmaster pro'pro's in both 16 and 28t. The 28 is an awesome crawler with good torque but super slow. The 16t on 3s is great imo. Plenty fast and still has great low end grunt. But the best way to know for sure is try one. Pull the trigger one one and run the crap out of it lol. And if ya don't like it you can always try trading it off in the classifieds
12-08-2014, 11:10 AM | #11 |
Rock Stacker Join Date: Mar 2011 Location: Madison, Alabama
I'm running a 27T HH TM Pro on 3S and it has plenty of wheelspeed with good low end but I believe I'll be going to a 13T next. My buddy is running a 13T CM Pro in his and it has better startup and a touch faster than my 27T TM...I don't really know how fast it is but it's geared 16/87 and the motor stays plenty cool unless I'm running the ever living crap out of it for over 30 mins..... |
12-09-2014, 10:34 AM | #12 |
thanks for the feedback .. I orderd the 13t from ckrc .. will run with my sv3 esc on 2s most of the time .. ill figure out gearing but probably start with stock gear keep and keep an eye out on temp .. then drop down to 16t if I need.. next mod will be 32p gears ..already god drive shafts installed seriously thanks guys |
brushed motor question for wraith - Similar Threads | ||||
Brushed Motor Timing Question | Lou-Dog | Electronics | 5 | 05-12-2012 09:38 AM |
Brushed motor question | EMUTT | Electronics | 5 | 08-06-2011 08:59 AM |
Old brushed motor capacitor question | jclampy | Electronics | 7 | 05-06-2011 10:39 PM |
Brushed motor question | Synister_Intent | Team Losi Comp Crawler | 16 | 12-12-2009 01:36 PM |
