Re: built not bought. Thanks oiler. pretty proud of that extended output. It's held up to quite a few battery's now on 2-4s. Here's a pic from today on the rocks at home. http://i661.photobucket.com/albums/u...psloaph0j5.jpg Contemplating building a second rig. Now that I can build on the cheap |
Re: built not bought. Decided it was time make my non sensor ed 1/8 scale motor crawl with the big boys. It already holds its own and runs with them but isn't as smooth there's a few place s where just a little smoother will get through with no wheel speed. I also wanted to see how far I could take it with a big spur. Pictured is a 66 32p just barely clears my output. The other outputs on the market will clear bigger of course the spur cover I'd not going to fit but who cares. This was a test fit only as I have no room to bolt a pinion gear on. My 1/8 scale motor is sticking out past the skid plate I'll probly settle on 12 pinion and 60spur. My current gears are 14x58. though I dig the 66 spur I'm in crawler trailing mode so I may get a smaller 1800kv airplane motor that doesn't stick out past the skid plate and realy be crawling. http://i661.photobucket.com/albums/u...pszuaqd7a7.jpg http://i661.photobucket.com/albums/u...psk4o334m2.jpg |
Re: built not bought. I've got 64/11 32p on mine, with a 540 sized motor though. Respect for the building, I buy as little as I can get away with. |
Re: built not bought. ThanK you. I'll order a 64 and 60. I'll also need to fab a little cover over the spur to keep cables off. |
Re: built not bought. blast from the past <iframe width="560" height="315" src="//www.youtube.com/embed/G8hOmuX_Xec" frameborder="0" allowfullscreen></iframe> |
