Thread: 32p spur on Wraith kit
Old 12-16-2014, 05:18 AM   #1
Default 32p spur on Wraith kit
As part of Wraith vs Yeti, Kit vs RTR debate I’m having (mostly with myself), I’d like to hear some opinions:
Assuming I go ‘Wraith kit – Brushless’: will upgrading to 32p spur/pinion be viable?
The Spawn is equipped with a 32p spur. And comparing the manuals/ partnrs. I believe I could easily fit the Spawn spur and slipper plates. Only difference I see is the 32p gear axle is 1mm longer.
Also the 32p is geared lower (56/12 = 4.67) compared to the 48p (80/20 = 4), which is not a big issue considering I’m going brushless (KV’s to be determined)
What I found in parts totals about $40.
AX30723: $6.00
AX31026: $6.25
AX31207: $5.00
AX31068: $5.00
AX31180: $8.00
AX31149: $9.00
I don't know what Harley's Supershafty-Slash-slipper assembly will add up to.
Any comments?
wouterb is offline   Reply With Quote
Old 12-16-2014, 05:53 AM   #2
Default Re: 32p spur on Wraith kit
If you are even Hallucinating about going brushless, Don't be afraid pull the trigger Super Shaft ultimate top shaft and Robinson Racing 32 pitch steel spur and slipper assembly.
DrDiff952 is offline   Reply With Quote
Old 12-16-2014, 07:39 AM   #3
I attempted this 32p upgrade on my Wraith kit. Upon securing the cover (AX8007 I found it doesn't fit....the spur hits the outer cover?!?!? The new dual slipper setup does not use the plastic spacer (AX80051 # which I left off when I assembled mine together.
Its almost like the alum spur gear spacer is too long. Checking the manuals which lists AX31180 (alum spur spacer) separately, upon receiving all of the parts listed above folks will notice an aluminum spur space IS included with AX31149 (updated top shaft). Thinking there is reason Axial has a separate part number, I matched the two spacers up and they're identical.
I do not see how I could possibly have installed these parts incorrectly...at this point I'm lost and hoping someone else has done this upgrade can lend some advice.
I will post up some pics once i get back to the house.
scraps is offline   Reply With Quote
Old 12-16-2014, 09:26 AM   #4
Duratrax 56t spur for the Nitro Evader is a direct fit to the old slipper that comes with the Wraith kit. No mods needed other than a matching pitch pinion. Will fit under spur cover.
Odd-M is offline   Reply With Quote
Old 12-16-2014, 09:31 AM   #5
Thank you for the tip...i may go that route. I'm hoping to use the parts I already purchased especially the dual slipper. Either I have a wrong part or I have overlooked something during assembly.
Old 12-16-2014, 10:31 AM   #6
That's what I did I couldn't get the duratrax spur to go on my slipper I had to take some sand paper and ever so slightly sand the inner circle. Then it went on no problem
xsputnikx is offline   Reply With Quote
Old 12-16-2014, 10:39 AM   #7
The single slipper holds up to 4600kv on 3s and a lot of abuse from me. Any 32p spur with the multi-hole pattern will fit, I believe mine is a Kimbrough.
Tighten it down all the way, then back off just a nudge.
maslin is offline   Reply With Quote
Old 12-16-2014, 02:29 PM   #8
It appears in the pics of some Spawn tranny part outs on Ebay, the gear cover is slightly different than the Wratih kit/RTR cover even though the part number is the same.
Old 12-18-2014, 11:28 AM   #9
Is the Duratrax spur made of steel or Delrin? If delrin; hoe does it compare to (hardened) steel?
Also I see offers of gears in 'tungsten carbide'. No idea what material that is?
Old 12-18-2014, 11:56 AM   #10
RR slash 32p 56t spur....u can still use the stock spur cover cause it clears just fine and having a beefy setup is a plus
gsrcivic is offline   Reply With Quote
Old 12-18-2014, 12:56 PM   #11
Plastic material, don't know what but it works. I really don't see the need for a steel spur. I've ran all my cars with plastic spur and I've only stripped ONE single spur the last 3-4 years. The trick is to have the mesh properly adjusted.
Old 12-18-2014, 01:05 PM   #12
I really like this traxxas slipper and 32 pitch gear. Direct replacement for the stock slipper assy.
54 T spur with 10 T pinion gives a perfect 5.4:1 ratio
Smaller spur leaves room for max shafts and yokes
Slipper works way better than stock
Super cheap & and easy.
http://www.ebay.com/itm/5507-Traxxas...item20ebe8e9c2
Dostradamas is offline   Reply With Quote
Old 12-18-2014, 01:48 PM   #13
64t is the largest I could fit with MIPs.
64/11 is still fast on 4600kv and 3s
Old 12-19-2014, 08:17 AM   #14
All this is great info...thanks! I tried to open up the 3 holes on the traxxas 56T spur but could not get it right as once installed it was not properly centered, only wasted a few $. I since ordered the Duratrax spur and a few different pinions in 12, 13 and 14T to try out. Stinks I have all these parts for the updated dual slipper and I can use them without a gear cover from a Spawn.
Old 12-19-2014, 08:39 AM   #15
So toss the cover. I gave up on it a while ago, never caused any issues.
Old 12-19-2014, 10:35 AM   #16
Yeah...i contemplated that as well, thanks!
Old 12-19-2014, 11:16 AM   #17
My duratax. 32p. Direct bolt on is holding up to a year of 200 running 4-6s. I'm running 56/14. Plenty fast on 4-6 with gobs of low end grunt from the 2650watt motor. Everything else will tear apart but the spur gear is strong even though it's not metal
evan03 is offline   Reply With Quote
Old 12-19-2014, 05:46 PM   #18
I'm with maslin, ditch the cover, I don't use them either
RealDeal is offline   Reply With Quote
Old 12-20-2014, 12:40 AM   #19
Yup ditch cover. Only place I eat spurs is the sand so those get steel. But sand eats everything else
Joshs4x4toyz is offline   Reply With Quote
32p spur on Wraith kit - Similar Threads
Wraith Spur Pinion shootout 32p vs. 48p Willy Smellson Axial Wraith 22 08-12-2014 06:21 AM
32p spur toka100 Axial SCX-10 2 11-06-2011 06:36 PM
