12-24-2014, 07:27 PM | #1 |
Newbie Join Date: Jul 2014 Location: Midland
| Motor esc connection
The connection between esc and motor looks a little burnt up. Could I just solder on some deans connectors or is there a bigger issue causing this? When I turn on the rig I get steering but no forward or back. |
12-24-2014, 07:38 PM | #2 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: Motor esc connection
For brushed motors use WS Dean's but configure them so that you can plug the motor directly to the battery pack.
12-24-2014, 07:38 PM | #3 |
If you go brushless use the barrel connectors
12-24-2014, 07:59 PM | #4 |
It's brushed. I'll put some deans on there and see if that helps. I'm getting no lights on my esc and it's the stock wraith motor. It might just be a burned up motor?
12-24-2014, 07:59 PM | #5 |
Rock Stacker Join Date: Apr 2014 Location: Altoona,Florida
I had this problem all i did was upgrade to a different brushed system
12-24-2014, 08:51 PM | #6 |
Thanks for the replies.
12-24-2014, 09:15 PM | #7 |
Newbie Join Date: Dec 2014 Location: West Plains, Missouri
I had a problem similar to this once before but the connectors didn't look burnt like your's. My black wire that connects the esc to the motor would smoke if I applied any gas, I didn't have any forward or reverse, but the steering still worked. Turns out the motor was just blown. I would replace the motor and see if that solves anything. Good luck, bro. |
12-25-2014, 03:45 PM | #8 |
Rock Stacker Join Date: Jun 2014 Location: Perth
The black is due to arcing.... The connection is poor, that's all... Some needle nose pliers and tighten the female plug a bit will solve the problem
12-26-2014, 02:51 AM | #9 |
Rock Crawler Join Date: Mar 2012 Location: UK
Use 4mm bullets, it's what comes standard with the BRXL and is the minimum needed for motor connections imo
12-26-2014, 03:06 AM | #10 |
I joined the Band! Join Date: Dec 2014 Location: Earth
For brushed motors I always used Dean's Ultra Plugs and 12awg wire, for brushless 540's and 550's I'm using 3.5mm bullets with 12awg wires. Been just over two years on the 3.5mm and haven't had a problem in my short course (2wd and 4x4) or stadium trucks running on 2S and 3S. Haven't had chance to run the 3.5mm on a crawler yet, still in the early stages of building it, but I don't expect them to be a problem with the Sonic or LRP brushless motors plan to use.
12-26-2014, 07:19 PM | #11 |
Pebble Pounder Join Date: Oct 2014 Location: bellville
I wire mine direct. I am running Tekin FXR 45T HD comb though.
12-26-2014, 09:08 PM | #12 |
Newbie Join Date: Feb 2014 Location: belleville
I use deans in all my rigs i concider tje best way tho
12-28-2014, 12:34 PM | #13 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
Xt60 would be more like what you have now. Bullets
12-28-2014, 12:39 PM | #14 |
RCC Addict Join Date: Jul 2008 Location: San Diego
High resistance, cut the wires and solder.
12-30-2014, 07:53 AM | #15 |
Newbie Join Date: Jan 2012 Location: Springfield, LA
I agree that soldering directly is the best method but if you tear your rig down often to clean it and maintain it then I would recommend deans connectors for brushed systems (what I use) and the 4mm bullets for a brushless system.
12-30-2014, 09:49 PM | #16 |
Quarry Creeper Join Date: Aug 2014 Location: San Diego
It also helps with deans if you tend to switch out motors often depending on terrain. I only have one motor but have deans for if I pick up another, all I have to do is unplug and plop it in.
12-30-2014, 10:21 PM | #17 |
RCC Addict Join Date: Aug 2009 Location: Earth?
No plug... Straight wire....
12-31-2014, 10:50 AM | #18 |
Deans plugs.
12-31-2014, 07:41 PM | #19 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Cut the connectors off solder directly to the motor , but motor could be fried.
01-03-2015, 10:15 PM | #20 |
Deans plugs only
Motor esc connection - Similar Threads | ||||
deans for motor to esc connection | 503dave | Electronics | 11 | 02-04-2014 01:30 PM |
Deans for motor connection? | jbsmith05 | Axial AX10 2nd-gen | 9 | 04-05-2013 03:23 PM |
battery connection to esc | klcrawler | Newbie General | 5 | 09-24-2011 11:01 PM |
question about motor-connection to esc | tomancik | Newbie General | 8 | 11-04-2009 05:57 AM |
question about connection esc - motor | tomancik | Electronics | 9 | 11-05-2008 10:28 PM |
