12-26-2014, 11:42 PM | #1 |
Rock Stacker Join Date: Jun 2005 Location: Port Moody, BC, Canada
| Ioco Off Road Warrior
This is my Wraith with a New Bright hard body Range Rover on its first run. Its modeled after the trucks on the show Alaskan Off Road Warriors on Discovery Chanel... although the stretch on this thing makes it a bit more extreme than those trucks. Its been hacked and drilled and needs some realignment. Once that's all done I'll clean up the body work and repaint it. Its mounted using 4 screw holes on the top edge of the door. The hood is cut and held on by 2 screws at the back. It may get another in the front but its secure with the 2 on the sides at the back. |
12-26-2014, 11:49 PM | #2 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: Ioco Off Road Warrior
What is the wheelbase on that body? Where did you find it?
12-27-2014, 09:44 AM | #3 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
Hopefully noone hates on this thing. For some reason I really like it.
12-27-2014, 12:17 PM | #4 |
| Re: Ioco Off Road Warrior The wheelbase on the body is 10.5 inches and the truck is 15.5 inches. Not sure if that's the stock wheelbase for a Wraith or not. I got the body off a New Bright toy RC I found at a local thrift store for $5. JIDIR, I've never had an appreciation for the look of the Wraith I prefer scalers or trucks with scale looking bodies. I have 2 other Chevy Silverado bodies that will fit this truck. The smaller of the two will be done as a rock race truck. I think the bigger one is big enough to build a decent looking scaler. Not too many people go in this direction with a Wraith so hopefully better builders will be inspired to do a better build than I have, I like the look of this truck but its not exactly the look I'm going for because of the shorter wheelbase. I will likely trim the rear quarters to make it a bit more of a rock racer look. I will post some pics of the underside but its pretty ugly. Its ok though because the original owner of this Wraith built it for seriously hard beatings and it will get used a lot. |
12-27-2014, 12:42 PM | #5 |
Quarry Creeper Join Date: Jun 2014 Location: San Mateo
Why are the bottom of your front shocks pointing rearward?
12-27-2014, 01:52 PM | #6 |
| Re: Ioco Off Road Warrior That's a good question. I don't know. Thats how the original owner/builder of the truck set it up. The owner of my LHS was impressed with how its built and it works awesome. Having said that I don't like how that looks. I can't move the tops back as it won't clear the front cage. I haven't tried moving the bottoms forward yet. Those shocks also have travel limiters that I may try removing. They are traxxas alloy shocks and the rears need a top mount extension to raise the back a bit because it squats at the moment. I will however try some stiffer springs too. This thing weighs over 7 pounds so it might do to have a little less sag in the back. |
12-27-2014, 01:58 PM | #7 |
Post up a picture of where it mounts at the bottom, it almost looks like it has been mounted to the lower link like a trailing arm setup (leading arm in this case) but you may be able to re-mount it to the axle where it was originally, the front suspension will probably work better for you.
12-27-2014, 01:58 PM | #8 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: Ioco Off Road Warrior |
12-27-2014, 02:10 PM | #9 |
12-28-2014, 07:21 AM | #10 | |
| Re: Ioco Off Road Warrior Quote:
12-28-2014, 12:58 PM | #11 |
I've never seen a setup like that before, the green ones and the bottom ones are normal, the "leading" links usually replace the lower links and have a place to mount the lower shock, normally the lower shock mounts to the axle in the upper mount hole above the lower link mount. That's an interesting setup.
12-28-2014, 01:06 PM | #12 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
12-28-2014, 02:26 PM | #13 |
RCC Addict Join Date: Aug 2013 Location: Missoula
I don't think I've ever seen a 6 link. It just has to bind up...
Ioco Off Road Warrior - Similar Threads | ||||
JRP RC - Building Road Part 2 The Rc Tonka Off Road Dump Truck! | Juddp | Scale Videos! | 0 | 10-12-2013 07:53 PM |
Ioco On the Rocks!!! | SteelHead[BC] | Scale Videos! | 4 | 01-01-2013 07:24 AM |
Off Road / On Road / Water / Air PC physics simulator game | BubbaEinstein | Chit Chat | 1 | 11-20-2012 03:16 PM |
on road race - off road mud truck | cammok5 | Chit Chat | 4 | 06-21-2007 08:15 PM |
