12-27-2014, 02:42 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Alabaster
| Axial spawn
Well as I take my brand new spawn out of the box today it had a broke lower front link so I went and ordered my vanquish 8 piece and a strc steering components. How does a product so expensive come out the box broke? Other than the broke part it seems to have a good layout though. Swap the link mounts around, add some weight to the front, move electronics around, put some dean's on connectors and put some carter panels on it'll be set. I do have a question the stock esc is rated 3s so will this 20t hold up or will it be like the first wraith? To the axles do you have to swap the internals around like the first wraith or did they finally decide to do it? Don't get me wrong love axial product but sometimes I wonder who boxes these things. Box looked brand new with no holes or scrapes
12-27-2014, 05:59 AM | #2 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: Axial spawn
I built the kit. I never knew that there were issues with lockers and pinions. I have heard of problems when people don't follow the instructions on installation
12-27-2014, 06:05 AM | #3 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
| Re: Axial spawn I got one of the first wraiths and it would go faster in revese than forward so had to swap the ring gear to the other side of the pumpkin. I'm not sure on the spawn. I know my kit that I just bought had it right in the instuctions.
12-27-2014, 09:43 AM | #4 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
| Re: Axial spawn Swapped the ring gets around? that won't change the speed at all just the direction the diff turns the axles. If it was going faster in reverse it sounds to me that the motor direction was backwards? |
12-27-2014, 10:19 AM | #5 |
| Re: Axial spawn
Nope motor was good ring gears were backwards so when u swapped them then changed your radio then everything was going the proper direction. That's why he asked the question I think the problem was with brushless motor installs.
12-27-2014, 10:26 AM | #6 |
Newbie Join Date: Oct 2014 Location: Huntsville
| Re: Axial spawn
I unboxed mine and started running it. Soon after I couldn't turn and noticed my servo was stripped, replaced it with a savox 0251 and metal servo horn. Have not had problems since.
12-27-2014, 08:45 PM | #7 |
Quarry Creeper Join Date: Jan 2009 Location: longwood, fl
| Re: Axial spawn
You will burn up the 20t quick with a 3s. Mine went Kaboom!
12-29-2014, 09:06 AM | #8 |
Newbie Join Date: Dec 2014 Location: Reader WV Wetzel County
| Re: Axial spawn
Bought my new Spawn yesterday love it !
12-29-2014, 01:24 PM | #9 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Axial spawn
Gear that 20 down a bit it will last longer & have more torque! |
12-29-2014, 02:11 PM | #10 |
Newbie Join Date: Dec 2014 Location: Springfield Area
| Re: Axial spawn
Bought a new Spawn Saturday. Stripped the steering servo Sunday. I replaced it with a Xpert WR7701 and had a blast with it today. No issues just fun crawling! I am running a 2s.
12-30-2014, 08:01 AM | #11 |
Newbie Join Date: Jan 2012 Location: Springfield, LA
| Re: Axial spawn
I'd stick with 2S and unless you get the gearing down to at least 5:1 instead of the stock 4:1, it won't take long to burn it up
12-30-2014, 08:05 PM | #12 |
| Re: Axial spawn
Well so advance work on mine last couple days. Here is the list. -Crawler innovations battery mount -savox 1256tg -castle bec -vanquish links wrapped with heatshrink -strc steering links -electronics moved to rear with custom plate -integy drive shafts |
12-30-2014, 08:05 PM | #13 |
| Re: Axial spawn
Still waiting on carter panels and dinky hood
12-30-2014, 08:06 PM | #14 |
| Re: Axial spawn |
12-30-2014, 08:06 PM | #15 |
| Re: Axial spawn
Also added some 110mm kings. These are for the slash or sc10
12-30-2014, 08:07 PM | #16 |
| Re: Axial spawn |
12-30-2014, 08:07 PM | #17 |
| Re: Axial spawn |
12-30-2014, 08:07 PM | #18 |
| Re: Axial spawn |
12-30-2014, 08:08 PM | #19 |
| Re: Axial spawn |
12-30-2014, 08:09 PM | #20 |
| Re: Axial spawn |
Axial spawn - Similar Threads | ||||
Wraith Spawn | jon_cue | Axial Wraith | 11 | 11-17-2014 01:31 PM |
Spawn | jlsandkes | Axial Wraith | 2 | 11-17-2014 01:27 PM |
Spawn of Violator's XR-10 build | The Violator | Axial XR10 | 21 | 10-11-2011 07:17 AM |
Spawn Skins for D71phair.. | Krawler Konceptz | Paint and Body | 10 | 03-29-2011 06:34 PM |
