12-27-2014, 07:55 PM | #1 |
Newbie Join Date: Aug 2014 Location: Louisville
| axial universal upgrade slop
Hey, I just upgraded to axial universals and now the drivers side wheel has some slop (pull side to side space)... wiggling... Bearings are good, axel is seated, it doesn't appear to be the u joint the whole assembly moves. Any ideas I'm out of em' Thanks |
12-27-2014, 09:12 PM | #2 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
| Re: axial universal upgrade slop
All of mine are like that and I use the traxxas shims in between the hex pin and the outer knuckle bearing.
12-27-2014, 09:14 PM | #3 |
Pebble Pounder Join Date: Dec 2012 Location: Vancouver
Mine do the same. Traxxas shims help.
12-27-2014, 10:02 PM | #4 |
IS there any way to shim the inner bearing? Just so it looks clean? Which shim kit? I see all kinds from traxxis |
12-27-2014, 10:11 PM | #5 |
Newbie Join Date: Jan 2005 Location: Ravenna
i used these shims - TowerHobbies.com | Traxxas Fiber Washers 5x8mm (20) still not happy with the result. might just buy some vp's if they fit better
12-28-2014, 05:43 AM | #6 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Fast Eddy has a shim kit for wraiths. I believe it's for the use of the VP disk brakes.
12-30-2014, 08:11 AM | #7 |
Newbie Join Date: Jan 2012 Location: Springfield, LA
A press fit locker or a locker with set screws will also eliminate the in and out slop. Just be sure the pivoting axis of the universal lines up with the rotation centerline of the knuckle or you will have binding issues.
axial universal upgrade slop - Similar Threads | ||||
no slop axial drivetrain? | theloudone | Axial AX-10 Scorpion | 10 | 07-30-2012 01:54 PM |
Trouble removing dogbones for universal upgrade | Scurvy | Axial Wraith | 9 | 05-03-2012 02:43 PM |
Axial XHD No Slop Lockers | highlandcrawler | Axial AX-10 Scorpion | 11 | 09-26-2011 02:27 PM |
Axial hex + VP hub = slop | BurnLatex | Axial XR10 | 13 | 01-28-2011 10:34 PM |
