12-31-2014, 10:37 AM | #1 |
Pebble Pounder Join Date: Nov 2014 Location: in the woods
| Trailing arm mounted shocks vs axle mounted shocks on a wraith?
Trailing arm mounted shocks or axle mounted shocks?!?!? What's the pros and cons of running trailing arm mounted shocks? I figure you could run a lil longer shock w/o raising the vehicle. I'm thinking of putting trailing arm setup on my wraith, just wasn't sure of the advantages ( if any) over the stock configuration. Any input is greatly appreciated |
12-31-2014, 10:39 AM | #2 |
| Re: Trailing arm mounted shocks vs axle mounted shocks on a wraith?
Forgot to mention.... I mostly crawl with an occasional trail run
12-31-2014, 10:57 AM | #3 |
the trailing arm/shock setup is a more progressive design...I have 2 rigs with them. the issue with using them on a wraith is the stock top location is too wide. you can redesign the top mount setup to work with the trailing arm/shock design, just needs to be narrower. I love the way it works, and wont go back to axle mounted shocks on those two rigs...I crawl and trail run about the same, crawling is much better with the trailing arms!
12-31-2014, 12:32 PM | #4 |
Thanks for the input!! Yea I figured the top mounts would be an issue. I was thinking I would make some sort o bracket to mount em up top. Was thinking of mounting them higher on the chassis and using a longer shock
01-01-2015, 11:57 AM | #5 |
Rock Stacker Join Date: Feb 2014 Location: Michigan
post some pictures of your set up
01-02-2015, 06:11 AM | #6 |
| Re: Trailing arm mounted shocks vs axle mounted shocks on a wraith? |
01-02-2015, 06:46 AM | #7 |
RCC Addict Join Date: Aug 2013 Location: Missoula
I don't see trailing arms...
01-02-2015, 07:20 AM | #8 |
correct.... if you read throught the first post I said im thinking of getting a trailing arm setup, so I was just trying to see if anyone else minded sharing their experience with the trailing arms on a wraith
01-02-2015, 07:22 AM | #9 |
RCC Addict Join Date: Feb 2012 Location: UK
I think he thought the pic was from allanon1965
01-02-2015, 09:15 AM | #10 |
| Re: Trailing arm mounted shocks vs axle mounted shocks on a wraith? I have 2 rigs with the trailing arms..
01-03-2015, 09:13 AM | #11 |
Quarry Creeper Join Date: Nov 2012 Location: Springfield, MO
Is that the DMG stiffy kit or who made that back half?
01-03-2015, 01:24 PM | #12 |
Newbie Join Date: Jun 2014 Location: Fort McMurray, Alberta
I run the BlueMonkey trailing arm setup in my wraith and its great, stiffens up the rear of the chassis pretty good, you need to do the battery forward mod thing if your running trailing arms though because you need to remove your battery tray. The flex is great, tires will now rub the chassis at full flex. I'm running dual shocks with a 110mm king and a stock wraith shock with the spring removed for dampening, works great.
01-03-2015, 01:29 PM | #13 |
Gotta realize trailing arms are all about maximizing travel out of a given shock length. The trailing arm is nothing more than a lever. Dual dampeners make zero sense other than being scale or showing off.
01-03-2015, 08:16 PM | #14 |
| Re: Trailing arm mounted shocks vs axle mounted shocks on a wraith? with one of mine, one has fluid and one has the springs....works like magic on the trails and rocks...I just like the look of dual shocks, but there is only one dampening movement Last edited by allanon1965; 01-15-2015 at 02:37 PM. |
01-03-2015, 08:19 PM | #15 |
| Re: Trailing arm mounted shocks vs axle mounted shocks on a wraith? yup, the shortback dual shock trailing arm stiffy kit by the one and only Jerry! also showing the longback dual shock trailing arm stiffy kit that is the only one in existence as far as i know right now...Jerry custom made it for me a few months ago |
01-13-2015, 07:42 PM | #16 |
here are 2 views of my rig with trailing arms and my other rig without them. You can see the body has significantly less body lift and roll with the dual shock trailing arm, this rig has oil in both shocks, 25wt in the front one and 35wt in the rear piggyback. My other rig works better with oil in the piggyback shock and none in the front..each rig set up is different so a little trial and error is needed but well worth it.
01-14-2015, 04:53 PM | #17 |
EeePee, im running 2 shocks because I find the stock Kings don't have enough dampning, but with another shock without the spring the work perfect
01-14-2015, 05:06 PM | #18 |
Thicker oil works. Or different pistons.
01-14-2015, 05:40 PM | #19 |
sometimes its not as simple as thicker oil or changing the pistons...different setups respond differently to the same shocks, or oils or piston designs......some people dont mind or notice the differences some do. No right or wrong about it, just different. Find what works for you and leave it at that, if you change parts later down the road, you may find that you have to fine tune your setup again. no one rig is exactly the same as another even though they may be built with the same parts. |
01-14-2015, 05:41 PM | #20 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
trailing arms help you achieve more travel out of a shorter shock. at the same time, it creates a much smaller motion ratio and requires more out of the shock (spring rate and dampening).
Trailing arm mounted shocks vs axle mounted shocks on a wraith? - Similar Threads | ||||
Front shocks mounted SMC 4.5EX H2 Video included | Savage00 | Losi Micro-Rock Crawler | 6 | 08-12-2011 06:27 AM |
Axle mounted shocks | BADASSPONY | Redcat Crawlers | 5 | 02-02-2010 09:34 AM |
link mounted shocks | spacessj | Tamiya Clod Buster | 4 | 10-26-2005 01:19 PM |
Arrow links & link mounted shocks | rckjeep | General Crawlers | 11 | 08-28-2005 12:28 AM |
t maxx shocks mounted in stock position? | bigdangerous | Tamiya Txt-1 and Juggernaut | 1 | 10-23-2004 08:10 PM |
