01-15-2015, 10:20 AM | #21 |
Quarry Creeper Join Date: Oct 2014 Location: Barre
| Re: Wraith Kit
Looking great. Glad to hear it performed well. I'm at the point where I need to cut the Lexan. Unfortunately, not confident the painting will go well with the temps below zero here! |
01-15-2015, 11:07 AM | #22 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Wraith Kit Temps and in the 40°'s here, not great for painting but I could get it done with a small space heater. However, the rain seems to hit every 36-40 hours, so there's no chance of getting anything to stick right.
01-15-2015, 11:20 AM | #23 |
Rock Stacker Join Date: Dec 2014 Location: South of columbus Indiana
| Re: Wraith Kit
Thanks motopreserve! I was running the salamander in the garage to get my painting done. Hope yours goes well! John |
01-15-2015, 12:26 PM | #24 |
| Re: Wraith Kit
I really wish there had been better photos of the cut pieces in the instructions. Some of the lines were non-existent and the pressure to get it perfect is intense!!! I have a propane wall unit at the bike shop. It does "ok" when it's below zero. If I could hit it and quit it, no biggie. But I want try to do it right, so the painful part will be waiting between coats and for it to dry! Did you sand the edges at all before painting? I feel it could be a little neater in some spots but not sure how Lexan takes to fine grit wet/dry paper. Thanks. |
01-15-2015, 04:37 PM | #25 |
| Re: Wraith Kit
I used a dremel with a med sanding drum. I did it before I painted. I need to straighten up some of the lines after painting as it's more noticeable, and some paint shows on the edges. I figured that should clean it up nicely.
01-15-2015, 04:57 PM | #26 |
Newbie Join Date: Apr 2011 Location: ca
| Re: Wraith Kit I put the toe rod below the knuckle bracket and the drag above the bracket with a small spacer in between the top 2. Truck looks awesome
01-15-2015, 05:11 PM | #27 |
| Re: Wraith Kit
Thanks for the Dremel tip. I'm sure the paint makes things stand out - so I'll give it a shot before I paint.
01-15-2015, 05:27 PM | #28 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Wraith Kit
I had put up with a similar issue with the tie rod (even though I had VP knuckles) till I was working on the servo arm hitting the bumper & found I could improve the tie rod clearance at the same time. Initially I just changed out the stock servo posts to some RCBros posts, they're a much slimmer design. To get a little more clearance I then made my self a new servo plate, I hadn't at that point discovered the DCW de-wanger, that moved the posts back another 2mm. That solved the servo arm hitting the bumper. It had the added advantage of pulling the servo horn & drag link back from the tie rod, which allowed me to roll the tie rod up a little which let it fit over the diff cover a little better . It did however introduce a clash between the servo horn & the diff cover when turning left, this was solved by flipping the servo over & running the drag link to the left instead of right knuckle. RCBros posts RC Bros Aluminum Servo Posts | RcBros Hobbies DCW De-wanger Web Store |
01-16-2015, 03:12 PM | #29 |
| Re: Wraith Kit
I had to spin the servo mounts 180 deg. to get the horn not to hit. A little more work removing the servo now. Hopefully I wont need to do that anytime soon. I think the lowering kit caused some of that too though. John |
01-16-2015, 03:20 PM | #30 |
| Re: Wraith Kit
I'm still using the stock mounts. Not replacing until they break :-) |
01-16-2015, 03:29 PM | #31 |
| Re: Wraith Kit
I have about an 1/8" clearance at full compression |
Wraith Kit - Similar Threads | ||||
wraith rtr/builder kit , ax10 ridgecrest or scx10 kit hocho/dingo | xC Pirates | Newbie General | 9 | 06-09-2012 06:54 AM |
