01-10-2015, 01:50 PM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: Grand Blanc/Traverse City
| Wraith Drive Shaft conversion with hot racing transmission
Hey guys, Big problem that I did not foresee. I put the hot racing transmission for the scx10 or ax10 into it with the extended front output shaft figuring i could just cut down the front shaft which is not a problem. The big problem that I do have is that the rear has a shorter shaft layout then the stock transmission. At full extension I need a 108MM so I would guess 110 shaft for the front and the rear at full extension is 145mm. I was looking at the MIP stuff but I am open to others if anyone can point me in the right direction. I am looking on the MIP site and everything seems to be listed by truck rather than by length. Please help, this is the last piece of my custom wraith puzzle |
01-10-2015, 02:15 PM | #2 |
| Re: Wraith Drive Shaft conversion with hot racing transmission
Cut tmax or revo shafts to fit. I would build a few sets for what a single set of mips cost that might not work. |
01-10-2015, 02:19 PM | #3 |
will they fit the 5MM outputs?
01-10-2015, 02:23 PM | #4 |
i assume you are talking about these https://traxxas.com/products/parts/5451X so I would nee to drill out the 4MM to 5MM or am I missing something here? |
01-10-2015, 04:22 PM | #5 |
Rock Stacker Join Date: Aug 2007 Location: Ventura, Ca.
have you looked at the SuperShafty out put shafts, I think they have what you need
Wraith Drive Shaft conversion with hot racing transmission - Similar Threads | ||||
Hot racing rock racer chassis conversion | Detour | Axial AX-10 Scorpion | 0 | 01-18-2014 02:34 PM |
Hot Racing transmission | BigSki | General Scale Talk | 2 | 07-28-2009 06:25 PM |
Shafty Conversion to Hot-Racing MOA | '04 Rubicon | General Crawlers | 64 | 12-04-2008 09:13 AM |
New Hot-Racing AX-10 Transmission?? | Szczerba | Axial AX-10 Scorpion | 23 | 10-22-2008 06:25 PM |
