01-15-2015, 05:00 PM | #1 |
Newbie Join Date: Apr 2011 Location: ca
| Does a CMS reduce steering throw?
Does it limit the steering or does it have just as much? Just looking for the pros and cons of the mod. I dont want to get it if it causes articulation issues or limits steering
01-15-2015, 05:03 PM | #2 |
| Re: Does a CMS reduce steering throw?
With the proper servo horn it will not limit steering. It may limit flex depending on the length of shock you run. It is made to hide the servo mainly, so unless that is your main concern, it may not be for you. |
01-15-2015, 05:30 PM | #3 |
I joined the Band! Join Date: Dec 2014 Location: Earth
It also tends to add bump steer. The axle mounted servo is a clean a simple system that works, I would leave if there unless you want to get the servo off the axle for a more scale look.
01-15-2015, 07:40 PM | #4 |
if it is set up properly there is no bump steer. I lost no steering throw with mine. It also helps keep the servo up out of water,mud,debris when trailing.
01-15-2015, 07:49 PM | #5 |
| Re: Does a CMS reduce steering throw? |
01-15-2015, 07:59 PM | #6 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
i didnt lose any steering but it limited a little bit of articulation but its not enough to matter at all. also im still confused about how people complain about bump steer with RC cars. for the longest time my panhard and drag link were wayyyy off from parallel and i can only assume i had bump steer. now my panhard and drag link are legitimately perfect and it drives exactly the same to me. sooooooooooo my opinion basically is worth nothing
01-15-2015, 08:22 PM | #7 | |
| Re: Does a CMS reduce steering throw? Quote:
...and I'm not complaining, just letting those that don't already know it's one of "cons" to the chassis amounted servo. It's a novelty for those who want a more scale appearance and it certainly does look better. | |
01-15-2015, 08:26 PM | #8 |
i dont think bumpsteer is going to matter much. the truck is slow and i only crawl, no bashing. 55t motor. and a hitec 7955 with aluminum horn. sounds like ill be ordering the kit. thanks!
01-15-2015, 08:28 PM | #9 | |
01-15-2015, 08:47 PM | #10 |
| Re: Does a CMS reduce steering throw? But it can knock you off your line in the RC car and that's something most drivers would like to avoid. Potential bump-steer is something everyone considering buying a chassis mounted servo kit should be aware of.
01-16-2015, 06:11 PM | #11 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
On the setup I'm running it took awhile to get it tuned in so the steering and suspension worked well together. There's been others drive it and were surprised how well it performed with the chassis mounted servo. I three linked the front, had to fiddle with the lengths of the steering horn, tie rod, and panhard bar to get equal throw to both sides (That took the longest. Can't just eye it, have to actually get out and test) and ended up putting suspension limiting straps on to reduce travel. Trick I'm using to keep excellent steering regardless of the minimal bumpsteer it has (Noticible on uneven terrain with tight turns) is to overdrive the front diff and underdrive the rear so the front end pulls it around. There's benefits and downfalls to this. But if your patient, you can tune it to perform like the axle mounted servo rigs. |
Does a CMS reduce steering throw? - Similar Threads | ||||
hand bros cms kit. cant get even throw | m1009cucv | Axial SCX-10 | 1 | 05-04-2013 06:24 AM |
xr steering, but no throw? | 0260b4u007 | Axial AX-10 Scorpion | 32 | 02-26-2013 12:19 PM |
cms and steering throw | nafie | Axial SCX-10 | 0 | 04-25-2010 07:47 PM |
Steering throw????? | WKcrawler17 | HPI Wheely King | 13 | 06-30-2009 01:24 AM |
Steering throw | hitman46mod | HPI Wheely King | 6 | 11-22-2007 01:21 PM |
