HARD TO FIND! VP Stage One Kit Can't find one these VP kits anywhere! Everywhere says out of stock. Any idea where I can find one???? |
Re: HARD TO FIND! VP Stage One Kit Stage one is great but the scale chubs are best! Vanquish Wraith Scale Chubs Black (2) Then buy knuckles & lockouts separate. Cost more but get clamping style chub that really helps is worth it."thumbsup" |
Re: HARD TO FIND! VP Stage One Kit Quote:
Re: HARD TO FIND! VP Stage One Kit If you run these, can you use the stock wraith knuckles? Also, if you ran the VP knuckles, do you need to modify anything or run a longer steering links? |
Re: HARD TO FIND! VP Stage One Kit just get the vp steering link and a few turns out on the rod ends and it works perfect for the scale knuckles. I also agree many benefits to the scale knuckle/chub setup. Lighter, better chub fit, bump stops to protect your cvds and just look badass. |
Re: HARD TO FIND! VP Stage One Kit Check the Vanquish website frequently, they will pop up as available for a couple of days then back to out of stock... |
Re: HARD TO FIND! VP Stage One Kit RPP has the silver stage one kit in stock. I was about to order it but went for the scale chubs & knuckles from them instead. |
