01-26-2015, 12:46 PM | #1 |
Pebble Pounder Join Date: Apr 2013 Location: Charlotte, Mi
| Rc4wd steel wheels bind
Just got the rc4wd steel wheels for my Wraith but the pin drive hubs are binding against the knuckles or bearing face. Will the rc4wd aluminum hexes https://store.rc4wd.com/RC4WD-12mm-A...s-_p_1125.html and hex hubs OEM Steel 2.2 Stock Beadlock Wheel Hexes for these wheels work? Is stock width OK or do I need the wider hubs?
01-27-2015, 02:46 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: Rc4wd steel wheels bind
I run the slightly wider hexes on mine. Gives better clearance of the Knuckles. I also run Teflon washers behind the pins even when using hexes.
05-05-2015, 07:47 PM | #3 |
| Re: Rc4wd steel wheels bind |
05-05-2015, 08:25 PM | #4 |
That's the best way to go about it IMO, or go with the hex hubs. Rc3wd has whacky dims on stuff sometimes I've found.
05-06-2015, 05:42 PM | #5 |
Rock Stacker Join Date: Jan 2012 Location: Vancouver
Yep. I had to bore out the holes for the threaded end of my axles just to be able to get my wheels on and off. Their tolerances are pretty inconsistent apparently.
05-06-2015, 07:12 PM | #6 |
I came across that with 1.9 steelie pindrive hubs years ago. They were made way too deep. Just ended up abandoning them and went with hex hubs.
05-06-2015, 07:57 PM | #7 |
I joined the Band! Join Date: Dec 2014 Location: Earth
Got a set of those hubs with my 1.9" wagon wheels, they fit just fine on the SCX10 they were intended to fit. Didn't bother trying them on the Wraith since it's 2.2" and has a set of SSD wheels and hex hubs on it. Swapped the 1.9 pin drive hubs for the RC4WD 12mm hex brake rotors because I don't like pin drive wheels and I didn't like the hex nuts on the wheels. The rotors are threaded and use socket screws from the face of the wheels instead of the screws from the back and hex nuts on the face. As for the pin hub consistency, all the hubs are 7.28mm thick and the pin slots are all 2.42mm deep. |
05-06-2015, 08:37 PM | #8 | |
| Re: Rc4wd steel wheels bind Quote:
05-06-2015, 11:32 PM | #9 |
Decided to testl fit the RC4WD pin drive hubs on the Wraith while I had it apart, was cleaning some grass from behind the hexes anyway. The 1.9 pin hubs fit the front Axial universal axles fine and have .020" (.50mm) gap between the hub and bearing. The right rear has .018" (.45mm) gap between the hub and lockout and the left rear has a .014" (.35mm) gap. If you guys are running aftermarket axles, knuckles and/or rear lockouts, that could account for the poor fit and bind issues. But it could just as easily be poor quality control at the factory producing these hubs. If grinding .29mm (.0114") works, I say grind away. It's a little less hassle than sending them back and possibly getting more that don't fit. |
05-09-2015, 08:09 PM | #10 | |
11-05-2015, 09:13 PM | #11 |
Pebble Pounder Join Date: Dec 2012 Location: Vancouver
I encountered this problem tonight. Using wraith knuckles on scx10 axles. The outer bearing is flush in the knuckle unlike the scx10 ones I removed. I ended up sanding down the wheel hub with a sanding disc from my dremel kit mounted on a drill.
