01-28-2015, 09:35 AM | #1 |
Newbie Join Date: Jan 2015 Location: US
| Strengthening Rear Shock Mounts After Moving Battery Up Front
Im almost done with my Wraith kit and like how putting the battery where the ESC was gives me lots of room in the back to put the ESC and LED receiver switch components I want to put. However it looks like the battery tray adds strength to the rear shock mounts, but might not have room for a Radio Shack project box. So my question is would it be safe to remove the battery tray and keep the rear end strong? or use the dremel and shave some plastic to fit the box and ESC? Also seen some pictures of the Axial with a metal bar in between the rear shocks. Is there a part to buy or something you made? |
01-28-2015, 11:51 AM | #2 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Strengthening Rear Shock Mounts After Moving Battery Up Front
I think it's just a 7x60mm post from Axial (part #AXA1429) that fit between the shock mounts with the battery box removed.
01-28-2015, 05:26 PM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
It's an Axial 7x55mm post (AXIA142 thats the part # for grey. Depending on your esc/rx box etc arrangement it fits across the front also |
01-28-2015, 07:01 PM | #4 |
That's a confirmed 7x55mm, part number AXA1428. I put the calipers across it instead of the cheap tape measure and the caliper hit 55mm. Tape measure in now in the trash.
01-29-2015, 01:50 AM | #5 |
RCC Addict Join Date: Feb 2012 Location: UK
I have one of these. They work a treat. I have the front lower window brace to. Great for stiffening her up. Axial Wraith Aluminum Rear Shock Mount Black TopCad 23028 |
01-29-2015, 07:45 AM | #6 |
Thanks guys Might get the green ones. as im painting my Wraith with Duratrax Lime Pearl. Whenever the paint comes out. Last edited by Brickman; 01-29-2015 at 07:50 AM. |
01-29-2015, 10:03 AM | #7 |
Quarry Creeper Join Date: Dec 2013 Location: Central IL
Order mine just now!
01-29-2015, 10:06 AM | #8 |
Rock Stacker Join Date: Jan 2015 Location: Burlington, ON, Canada
| Re: Strengthening Rear Shock Mounts After Moving Battery Up Front |
01-30-2015, 05:08 PM | #9 |
| Re: Strengthening Rear Shock Mounts After Moving Battery Up Front That helps, but really need to tie into the lower part of the rear cage too. The lower chassis usually breaks the lower part right next to the screws where it bends down to join the skidplate.
02-01-2015, 05:56 PM | #10 |
| Re: Strengthening Rear Shock Mounts After Moving Battery Up Front Yeah, I saw that and I think I'll keep the battery tray there and trim a bit to fit a project box. The battery fits perfect after trimming the interior without needing the tray.
Strengthening Rear Shock Mounts After Moving Battery Up Front - Similar Threads | ||||
What is the purpose of moving the front shock hoops back? | alexchen86 | RC4WD Trail Finder 2 | 9 | 09-12-2012 05:12 PM |
Benefit in moving lower shock mounts further out on axles? | Hoosierdady | General Crawlers | 7 | 09-08-2012 08:34 PM |
Moving battery tray to front | nightfiref7efi | Axial Wraith | 10 | 07-30-2011 11:39 PM |
moving battery to front axle? | trevdogg420 | Axial SCX-10 | 4 | 12-21-2009 08:18 AM |
Moving battery over front axle | moddersunited | Venom Creeper | 8 | 03-08-2009 12:57 AM |
