02-02-2015, 10:52 AM | #1 |
Quarry Creeper Join Date: Jul 2014 Location: North Florida.
| 2wd-4wd
Can the trans be flipped and use the free wheel option of the dig to make the Wraith switchable from 2wd to 4wd ? And the lock out for some power brake burnouts ? |
02-02-2015, 11:03 AM | #2 |
| Re: 2wd-4wd
Sure can, use that set-up in 2 of my builds. Though in the Wraith you'll most likely lose the ability to use the interior or have to cut it significantly.
02-02-2015, 11:05 AM | #3 |
| Re: 2wd-4wd
Awsome.. now is this the stock dig or aftermarket that has the free wheel option ?
02-02-2015, 11:44 AM | #4 |
Pebble Pounder Join Date: Feb 2007 Location: Monrovia
| Re: 2wd-4wd
The stock dig has freewheel and lock as options. Selectable with a 3position channel.
02-02-2015, 12:41 PM | #5 |
| Re: 2wd-4wd
The only 3ch I have is the Traxxas and its not a 3 way rocker switch just a 2 way.. I take it I would need a 3rd channel with a 3 way switch ? |
02-02-2015, 12:43 PM | #6 |
| Re: 2wd-4wd
Or can I do away with the lockout and use only tge free wheel ?
02-02-2015, 06:23 PM | #7 |
| Re: 2wd-4wd
Way too little movement to do that. No way to control that on the tq radio. There is a way to mod that radio to a 3 position 3rd channel. Do some searching and I'm sure you can find info.
02-02-2015, 06:39 PM | #8 |
| Re: 2wd-4wd
Or use a longer servo horn for more movement. Even I admit that might be a tough one to search for, and I just happen to know who posted it so, here How To: Convert a Traxxas TQ3 for 4ws I did it a while ago with a RC4WD trans in a Tamiya Hi Lift and it was neat for a few minutes. |
02-02-2015, 06:45 PM | #9 |
| Re: 2wd-4wd |
02-02-2015, 07:05 PM | #10 |
| Re: 2wd-4wd |
02-02-2015, 07:15 PM | #11 |
| Re: 2wd-4wd
Would that do it ? Only wanting 2x and 4x not lockout.
02-02-2015, 08:37 PM | #12 |
| Re: 2wd-4wd
Yeah. You could grind the teeth off the lockout side of the center gear. I would do it slowly as to not compromise the integrity of the gear.
02-02-2015, 08:40 PM | #13 |
| Re: 2wd-4wd
Ok cool. Im looking up close up pics of the dig unit to see how hard it would be. Thanks. |
02-02-2015, 10:20 PM | #14 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: 2wd-4wd
If you only want 2wd/4wd that's only 2pos which so the Traxxas rocker switch should be fine, no need to mod that. You'll have to be careful using it for a dig servo however as the Traxxas radio has no end point adjustment for the 3/4/5 channels & you will more than likely burn out the servo your using for the dig 2wd/4wd control. Traxxas make it work by using a spring loaded servo arm. To me just reading the dig kit instructions, don't have one so I could be wrong, it looks like if you simple leave out part #AX30536-001 you'll have a drive disconnect rather than dig lock. You may need a small spacer to limit the slider dog from moving to far along the output shaft. http://www.axialracing.com/assets/AX...ponent_Set.pdf Last edited by altd896; 02-02-2015 at 10:39 PM. Reason: more/better info |
02-03-2015, 08:55 AM | #15 |
| Re: 2wd-4wd
I grind the tangs off the locker portion - 5 minutes with a dremel wheel. I have nightmares about the front getting locked if the servo glitches or whatever while on power. Now it won't lock the dig at all. For a 2 ch. radio, you can certainly do that, just mount the smallest servo arm you can find, and put the linkage as close to the spline as possible. Drill a new hole in the horn if you can. If you cannot limit the throw electronically, you'll have to do it mechanically. A 3 position switch mod would be perfect, you would need the 3rd position anymore, but the throw limit of about 30 degrees is just about perfect (if that makes sense) |
02-03-2015, 09:01 AM | #16 |
| Re: 2wd-4wd
Thanks guys.
02-03-2015, 12:27 PM | #17 | |
Rock Stacker Join Date: Sep 2006 Location: Abby BC
| Re: 2wd-4wd Quote:
On my SCX10 I flipped the tranny/dig. The rear end is too light so it just hopped and skipped over the place in RWD, but with the front locked you could do some nice donuts and brake stands. With that being said, I've flipped mine back to normal. | |
2wd-4wd - Similar Threads | ||||
2wd Or 4wd | murlin12 | Non Crawler RC's | 1 | 02-07-2013 08:22 AM |
2wd/4wd | k9500winmag | Axial AX-10 Scorpion | 2 | 12-02-2008 04:06 PM |
2wd and 4wd | bigdodge88 | General Scale Talk | 23 | 11-10-2008 09:38 AM |
2wd wk to 4wd is it possible?? | Mikekx65 | HPI Wheely King | 11 | 04-20-2007 05:19 PM |
