02-02-2015, 11:32 AM | #1 |
Quarry Creeper Join Date: Sep 2014 Location: pacific northwest
| SLW Hubs
Which ones are best to get for the wrath I have seen some people say the 475 and others the 600? Also, Do I need to also get the 12mm aluminum hex adapters with the set?
02-02-2015, 05:33 PM | #2 |
Rock Stacker Join Date: Dec 2014 Location: South of columbus Indiana
| Re: SLW Hubs
I'm running the VP slw 475's. I don't think I could go narrower as the VP tierod with the trail ready wheels wouldn't allow it. They slw hubs will require hex mounting. I'm running axial. The VP clamping look good.
02-02-2015, 05:58 PM | #3 |
Newbie Join Date: Dec 2014 Location: Bullitt
| Re: SLW Hubs
I to run the 475 with the stock trail ready beadlocks I think the 475 hubs are about 1/8 in wider per side then stock which work great if you want to run the vp steering links because they rub on the stock wheels with the stock hubs. Running the 475 hubs give you about 1/16 inch clearance on the vp steering links. Yes you will need the 12mm hex adapters I runs the vp clamping ones also. |
02-02-2015, 07:50 PM | #4 |
| Re: SLW Hubs
Thanks guys. i do plan to run the stock hubs with the VP steering link so the 475 seems to be the way to go.
