02-06-2015, 07:09 PM | #1 |
Newbie Join Date: Feb 2015 Location: aus
| Which Hi Torque Servo S9157 vs
What would fit and be better for a wraith futaba S9157 High-Torque or futaba S9352HV High-Voltage High-Torque High-Speed Servo |
02-06-2015, 10:24 PM | #2 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
| Re: Which Hi Torque Servo S9157 vs
I prefer the S9157. It is a great all around servo.
02-06-2015, 10:45 PM | #3 |
at 425oz I assume it has more than enough torque for a wraith crawling?
02-07-2015, 06:48 AM | #4 |
Pebble Pounder Join Date: Feb 2007 Location: Monrovia
425 is a decent amount. I have a hitec 7955 and its 333. Does ok. Would like to upgrade one day to a 7950 bc its 486@7.4v
02-07-2015, 06:55 AM | #5 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
If you can get a hold of one, Holmes Hobby BL400. Titanium gears, waterproof, and just under 400 oz @ 6V. 472 oz @ 7.4V and almost 600 oz @ 8.4V! And fast, too. And retails for under $100 US |
02-07-2015, 08:46 AM | #6 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Whatever you get use a bec. High torque over 350 in lbs . High quality hi tec ,jr,futaba ,holmes ,you are getting a good servo. I think it's a luck of the draw the servo your shipped. Get one with a decent warranty. If it's not waterproof don't turn your truck into a submarine until you take precautions to properly protect from water usage. Some servos are waterproofed. Others are water resistant. Use accordingly.
02-08-2015, 06:01 AM | #7 |
Well Im going Holmes motor so I will go with the BL400. using the Mamba Max Pro do I need a BEC? (sorry Newb) |
02-08-2015, 06:03 AM | #8 |
or should I run the Holmes TorqueMaster BR-XL WaterProof instead of the Mamba max?
02-08-2015, 07:14 AM | #9 |
Either will be fine but you get waterproofing With the BRXL wp. And yes on the BEC.
