02-13-2015, 11:20 AM | #1 |
Pebble Pounder Join Date: Aug 2010 Location: Arvada
| Why is my Wraith slow?
I have a decently upgraded Wraith that I have just pulled out of hibernation and started making a basher/speed only type of rig. I've upgraded all of the links, servo, knuckles, C hubs, etc. I just installed a Mamba Max Pro and programmed it for 100% power in forward and reverse. I also installed metal trans gears and 32p pinion and spur in the 58/15 flavor. I am running 3s. I am guessing it's top speed is 8 mph and I feel it should be much faster. I tried 4s on it and didn't notice much difference. I am guessing the issue is the motor. It is a Novak 13.5t sensored brushless motor. I had it running 58/14 and it didn't really change anything. I was not really wanting to get the Novak motor but it was all my favorite crawler shop had in stock so I grabbed it. The low end power just isn't there either. It will not pull a tire in the air no matter how hard I hit it. I am running no weight in the wheels or on the car at all. Battery is still in the stock spot. I ran a HH Crawlmaster 13t on 4s with a HH waterproof ESC and it was quite a bit faster than I have right now. The brushed motor did not like the 4s power though. On 3s it was a similar speed as I have now but with lower(slower) gearing at the spur and pinion. What say you? What is it going to take to get this thing going fast? Last edited by 73bronco; 02-13-2015 at 11:27 AM. |
02-13-2015, 11:25 AM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Why is my Wraith slow?
Something is wrong... bound up or worn out.
02-13-2015, 11:28 AM | #3 |
| Re: Why is my Wraith slow? |
02-13-2015, 11:34 AM | #4 |
A 3300kv motor geared at 3.8:1 on 3s should fly, like 20-25. Try it sensorless and see what happens
02-13-2015, 11:36 AM | #5 |
02-13-2015, 11:38 AM | #6 |
Battery okay? Got more than one? Does it get warm at all after a full charge?
02-13-2015, 11:45 AM | #7 |
I joined the Band! Join Date: Dec 2014 Location: Earth
If you're wanting some speed try a Tekin Pro4 4000kV or the Castle 1410 3800kV 4-pole 540, and make sure you're not running the under drive gears (43/13) in the axles. The 13t and 13.5t motors really weren't designed for high speed/high RPM power. Maybe consider the over drive gears (36/14) in both axles as well as the Pro4 or Castle 4-pole 540's. |
02-13-2015, 11:50 AM | #8 |
| Re: Why is my Wraith slow? I've run it on 3 different 800mah 40c 3s packs, 2 different 1300mah 40c 3s packs, one 2200mah 40c 3s pack and a 2200 mah 40c 4s pack. Not one has changed how it has reacted. I am wanting a bigger pack anyway so I am going to stop after work and get a bigger pack. The batteries are not even lukewarm after charging or running the wraith. The motor is slightly warm after running the entire 2200 mah 3s pack through it at mostly full throttle.
02-13-2015, 11:51 AM | #9 |
02-13-2015, 11:52 AM | #10 | |
| Re: Why is my Wraith slow? Quote:
02-13-2015, 12:02 PM | #11 | |
No battery temps means no work is being done. Your ESC setting correct? | |
02-13-2015, 12:09 PM | #12 |
Double check your ESC settings and check the transmitter as well. Sounds like you may only be giving it half throttle with the batteries not changing anything and the motor running relatively cool.
02-13-2015, 12:12 PM | #13 | |
I hooked the castle link up before doing anything and set the MMP up with 100% power for forward and reverse and calibrated the radio properly. | |
02-13-2015, 12:19 PM | #14 |
Which Novak 13.5 do you have? Novak part #3614 (Ballistic Crawler) is only rated at 2000kV. Ballistic Crawler Brushless Motors [#3614, #3618, #3619] Novak Electronics |
02-13-2015, 12:30 PM | #15 | |
02-13-2015, 12:37 PM | #16 |
You can drop a small diameter rotor in it for better speed, or I would recommend a 10.5 or 9.5 stator for the rotor it has. Or return it if they will let you.
02-13-2015, 12:39 PM | #17 |
| Re: Why is my Wraith slow? I'm hoping they will just let me return it. I don't really want to have to buy another part for a brand new motor they recommended to me when they knew I was going for speed only. They are very good so I am hoping they take care of me.
02-13-2015, 12:39 PM | #18 |
Ah, crawler version. Yeah, they'll getcha with those.
02-13-2015, 03:26 PM | #19 |
Just a quick update, the best hobby shop in Colorado took care of me as expected. Novak 13.5T crawler motor will be replaced with a Tekin 13.5T redline gen 2 motor on Friday. Bought a 60c 3300mah 3s to go along with it. |
02-13-2015, 03:45 PM | #20 |
You're going to hate me for saying this, but there's two Redline Gen2 13.5's also. However, one is #TT2407 @ 3400kV and the other is the #TT2406 "RPM" version @ 3600kV. Both are definite upgrades in the RPM department, so you should be fine with either one.
Why is my Wraith slow? - Similar Threads | ||||
Wraith Slow Motion | hugofly | Axial Wraith | 1 | 08-09-2013 09:27 PM |
Slow-go's Wrecked up Wraith | lonleycreeper | Axial Wraith | 67 | 03-15-2013 05:58 PM |
my wraith reverse is slow and weak.. | gordesky1 | Axial Wraith | 2 | 12-04-2012 04:11 PM |
What can slow a wraith down? | BrandonLowe83 | Axial Wraith | 4 | 10-05-2012 06:05 AM |
Super Slow Wraith | malekia | Axial Wraith | 10 | 09-11-2012 12:08 PM |
