02-13-2015, 08:56 PM | #1 |
Pebble Pounder Join Date: Jul 2012 Location: USofA
| Partially bulletproof transmission?
So my boy was playing with his wraith and had a young cousin pounce on it and somehow stripped the bottom gear and the idler gear in his transmission. Anyhow I now need to order some transmission gears, I was reading Harleys bulletproof thread and will eventually do the full upgrade but for now I just want to get him going again. The question I have is can I just buy the robinson racing bottom gear (the one that uses wraith stub shafts) and idler gear for now to get it going, then re-use the good robinson gears to do the full bulletproof transmission later as finances permit? Thanks for the advice. |
02-13-2015, 10:24 PM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Partially bulletproof transmission?
Absolutely. You'll probably find the gears will be all you need.
02-13-2015, 10:35 PM | #3 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
^^ X2 I've been running the RRP idler and lower diff gear, plus RRP Slash 32p slipper, with a ROC 412 3100 on 3s for almost a year. Most of the time it's driven by my 5 year-old, so it doesn't get babied. The tranny housing is stock. The only tranny problem has been a blown stock bearing that didn't like my water adventures, fixed by swapping to Fast Eddy sealed bearings.
02-13-2015, 10:58 PM | #4 |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
call super shafty and tell him what you want to do and he will get you going. Has the parts your asking about on his site.
02-14-2015, 08:26 AM | #5 |
Thanks guys, also does anyone know if the supershafty extended 6mm outputs will work with the stock wraith housing?
02-14-2015, 08:29 AM | #6 |
I believe the extended outputs are to run an ax10 style transmission on a Wraith skid plate.
02-14-2015, 09:41 AM | #7 |
Alright thanks.
02-14-2015, 09:52 AM | #8 |
he has 6mm outputs made specifically for the wraith. I had him build me a complete wraith bomb proof tranny last week for the king of the hammers recon g6. I talked to him for about 2 hours about all my different options and then just ended up going with his tried and true setup. plus with the lifetime guarantee you can't beat the price.
02-14-2015, 10:43 AM | #9 |
RCC Addict Join Date: Jul 2008 Location: San Diego
You can get the axial metal gear set. I changed to a standard Axial trans. You can drill out the motor plate that allows you to put bolts through the plate which is stronger. The gears are the same in the trans. I added a third bearing to the up of my trans. If you want to see the pictures its on my wraith build. With your son driving I would keep the slipper. Here is a cool way to adjust your slipper. Axial Wraith slipper clutch adjustment |
Partially bulletproof transmission? - Similar Threads | ||||
Charging a 8000 partially | prusik333 | Electronics | 7 | 06-25-2012 12:03 PM |
Bulletproof cv axles? | Pabust | Axial Wraith | 13 | 03-31-2012 11:21 AM |
BulletProof Clod Done | bulletproofcustoms | Tamiya Clod Buster | 14 | 09-17-2004 05:57 PM |
