Thread: Gmade 2.2 issue
Old 02-14-2015, 12:41 PM   #1
Default Gmade 2.2 issue
Hey guys, yes I have searched for 2hrs but cannot find a answer. I just picked up some gmade 2.2 mud rocks for my wraith and the center holes are too small for my hubs. Im using axial 12mm hubs. Only solution I see is drilling the center holes on the wheels out. Just wanted to check with other guys with gmade wheels. Thanks!
soscary is offline   Reply With Quote
Old 02-14-2015, 01:30 PM   #2
Default Re: Gmade 2.2 issue
I used to have the challenger series Gmade beadlock wheels and had the same problem. You will need to ream out the center section with a round file or body reamer which was what I used until it slides over the hub fully. Works great after that point and will seat flush on the hex. They were just designed for a slightly smaller hub is all, you wont have to ream out much at all as it already seats on half of the hex. Good luck.
Revoasian is offline   Reply With Quote
Old 02-14-2015, 01:31 PM   #3
Awesome. Thanks for the help.
Gmade 2.2 issue - Similar Threads
Gmade Going Under?? supermoturd G-Made Crawlers 24 03-09-2014 12:36 AM
MMP issue... i think i'm the issue. concretejungle Electronics 12 08-13-2012 02:52 PM
