02-18-2015, 05:15 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: UK
| Transmission Plate Mod
I have had issues with the grub screws for the lower links. If I thread lock them I strip them removing them. I also stripped one in the plastic plate due to debris getting in the head. Leave them just tight and they back off and I drop a link on the trail.... I know they should not need to be moved too often but the Rod ends will be replaced at some point. (plus I bought cheap links which had to be replaced ). The actual thread of the grub screw is the same as decent size bolt as in the first picture. So I have drilled out the holes to allow me a decent bolt with a good size head which can be maintained easier. I could have done with a slightly shorter bolt as you can see they don't sit flush. But they are tight and substantial and hopefully this is a permanent fix.... Time will tell. 😆 Just thought I'd share...Maybe there's was a better solution. |
02-18-2015, 05:23 PM | #2 |
| Re: Transmission Plate Mod
i just stick with the stock skid..never had an issue with screws backing out...or with the stock skid breaking...
02-18-2015, 05:49 PM | #3 |
Yeah I agree. stock skid. Slides better than aluminum and lighter too.
02-18-2015, 08:33 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
I was planning on doing something similar with mine next time I have skid off, don't like the small head in the set screws.
02-19-2015, 12:39 AM | #5 |
The issue with the stock skid was that I stripped the link screws trying to get the links out. So that ended up useless. Dirt got down the holes and into the head of the screw and before I realized the head stripped. I don't see much difference between them TBH. They both slide off rocks but I tend to drive as best as I can and not get high centered too often. I also figure it stiffens the Chassis which we all like. Less chance of the plastic tranny casing twisting and affecting mesh. I'm sure that was the reason I stripped the idle gear the first time round. |
Transmission Plate Mod - Similar Threads | ||||
hulksta Smash plate mod . | ctsami | Axial AX-10 Scorpion | 8 | 01-31-2015 01:06 AM |
Wraith Battery Plate mod | SloCrawlTx | Axial Wraith | 12 | 05-07-2013 06:25 PM |
Measurements for stock AX10 Transmission mounting plate/skid plate | Apoch | Axial AX-10 Scorpion | 5 | 04-09-2012 07:53 AM |
Skid Plate Mod | EeePee | Axial AX-10 Scorpion | 24 | 10-31-2007 09:59 PM |
My bumper/skid plate mod! | BB2 | General Crawlers | 2 | 11-08-2005 08:37 PM |
