02-20-2015, 07:08 PM | #1 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Why not 1.9 wraith build Ok guys this is my 1.9 wraith. The power plant is a Castle Creations Mamba max pro, motor is a 3300kv Tekin pro4. The transmission is all steel gears with a modified dig unit to run the front axle in free wheel. I did this so i can take the truck in and out of 4wd. Im running scx10 axles for now and will be swapping in the Veterra Ascender axles. I plan on using the built in high steer and built in panhard bar mount. I also like there size and one piece case. Parts used. Hitec Hs645MG steering servo Futaba S9551 shift servo Spektrum SR301 3-channel receiver Tekin Pro4 3,300kV 4-Pole Brushless Sensored Motor w/5mm Shaft Castle Creations Mamba Max Pro 1/10 Sensored/Sensorless ESC Visionary Fabrication Axial Ax-10 Dig System Axial Steel Locked Transmission Gear Set JunFac Hardened Universal Shaft for Wraith. In the rear will be swapped to mip Integy scx10 aluminum driveshaft front Axial Aluminum Knuckle Axial Aluminum C Hub Carrier Axial Universal Joint Set Axial Simple LED Controller Axial Threaded Aluminum Pipe Set 6x91mm Axial scx10 front and rear axles Wraith chassis Venom creeper shocks Last edited by greengoblin; 02-28-2015 at 06:12 AM. |
02-20-2015, 07:26 PM | #2 |
Rock Stacker Join Date: Apr 2014 Location: Altoona,Florida
| Re: Why not 1.9 wraith build
Looks to be a good build subbed Ren |
02-20-2015, 07:40 PM | #3 |
| Re: Why not 1.9 wraith build i dont have the othere axles yet but as soon as i do will build and add photos. I also need to gett a servo to shif the trans from 4wd in to 2wd. Updates to come. |
02-22-2015, 05:08 PM | #4 |
| Re: Why not 1.9 wraith build I got some run time in on the new build. I'm very happy with this rig so far very capable and stable. This is the compound we were at. Last edited by greengoblin; 02-28-2015 at 09:08 PM. |
02-22-2015, 05:46 PM | #5 |
| Re: Why not 1.9 wraith build I was bored so i added a rear light. I also added a set of aluminum c hubs and knuckles. Last edited by greengoblin; 02-23-2015 at 12:17 AM. |
02-23-2015, 04:07 PM | #6 |
Rock Stacker Join Date: Jan 2015 Location: Alabama
Nice job on the build! Jealous of the rig and the compound you've got there. Awesome job adapting that body to the Wraith chassis!
02-24-2015, 02:37 PM | #7 |
| Re: Why not 1.9 wraith build |
02-24-2015, 02:47 PM | #8 |
| Re: Why not 1.9 wraith build OK i got the disconnect working for the front axle. I used a Futaba s9551 @ 6.0v |
02-26-2015, 12:40 AM | #9 |
Newbie Join Date: Feb 2015 Location: Yucca Valley
Great build, starting my own 1.9 wrath build soon any advice or special parts needed to complete I have a donor scx10 and am working on getting the wrath. Thanks in advance
02-26-2015, 08:18 AM | #10 |
| Re: Why not 1.9 wraith build I used the axial 6x91mm links for the 4 link front and rear. You will need a 3x.50 tap. You will need to cut the front upper link bars to fit. This will stop the servo from pointing at the ground. I used a tube cutter you can get at autozone and you can get a small tap and die set at Home Depot for like $12. Can i ask what body your going to run? The jeep or the factory wraith panel set? I only ask do to the fact that the jeep and deadbolt body with scx10 shocks will let the tires rub the body so im using a 100mm shock. Last edited by greengoblin; 02-26-2015 at 12:42 PM. |
02-26-2015, 09:17 AM | #11 |
RCC Addict Join Date: Feb 2012 Location: UK
Great build. Whats the advantage of disconnecting the front wheels?
02-26-2015, 09:53 AM | #12 |
Newbie Join Date: Jan 2014 Location: Central WA, US
02-26-2015, 11:20 AM | #13 | |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
| Re: Why not 1.9 wraith build Quote:
I've been thinking about building a low slung high rpm street machine drift wraith. After seeing this I believe it would be awesome to have a similar setup for optional 2wd / 4wd. Looking forward to seeing what else you come up with. Nicely done so far! | |
02-26-2015, 11:32 AM | #14 |
| Re: Why not 1.9 wraith build I did the front end mod for the scale factor and i had never seen it done before. I dont have much run time with the front end woking that beeing the video. However seeing what i can crawl in 2wd is a big chang. |
02-26-2015, 02:12 PM | #15 |
| Re: Why not 1.9 wraith build I built teas and mounted them inside the chassis. Last edited by greengoblin; 02-26-2015 at 02:29 PM. |
02-26-2015, 10:24 PM | #16 | |
02-26-2015, 10:52 PM | #17 |
02-27-2015, 04:59 AM | #18 |
| Re: Why not 1.9 wraith build let me look it up and get back to you on that. |
02-28-2015, 05:02 AM | #19 |
| Re: Why not 1.9 wraith build I only used this servo beause it had a horn. I was going to use a Hitec SH645mg but i didnt have a servo horn and needed to order one for it. I will look up the name of the dig unit i have if you want that info. I have had the dig for about 2 years now sitting on a shelf. It just did not fit with the other projects i was doing at the time. Futaba S9551 Digital Low Profile Servo SPECIFICATIONS Speed: 0.14 sec/60° @ 4.8V 0.11 sec/60° @ 6.0V Torque: 98 oz-in (7.0kg/cm) @ 4.8V 122 oz-in (8.8 kg-cm) @ 6.0V Weight: 1.6oz (45g) Dimensions: 1.6 x 0.8 x 1.0" (41 x 20 x 25mm) Distance Between Mounting Hole Centers: 0.39" (10mm) Horn Screw Size: 3x8mm |
02-28-2015, 06:05 AM | #20 |
| Re: Why not 1.9 wraith build See first post for build update |
Why not 1.9 wraith build - Similar Threads | ||||
1.9 wraith build or scx10 build? | Cork | Newbie General | 13 | 06-08-2015 08:17 AM |
My Wraith Build | acesal | Axial Wraith | 29 | 05-02-2012 09:59 PM |
