Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Wraith
Thread: Harley Designed Venom Chassis Build
Old 02-24-2015, 08:36 PM   #21
I joined the Band!
Default Re: Harley Designed Venom Chassis Build
Originally Posted by vwdaveb View Post
It's probably right under my nose but: Were are Harley's downloadable plans at?
Had to find them myself yesterday.
Free RC Crawler Tube Chassis Design Templates | Harley Designs
Eric0424 is offline   Reply With Quote
Old 02-25-2015, 10:48 AM   #22
PSW
Looks like its really taking shape now Boover, Cant wait to see it finished.
PSW is offline   Reply With Quote
Old 02-25-2015, 10:56 AM   #23
Thanks! I've left out some of the bracing to wait till I get the overall form mocked up. Then the plan is to go in and add all the ever important triangles for strength. Remember kids, triangulation is your friend.
The stinger is going to be tricky. 4 bends in 2 different planes...
Boover is offline   Reply With Quote
Old 02-25-2015, 11:48 AM   #24
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Yes, definitely the one trick bend in the chassis. There is the option of cutting it into 3 pieces and sleeving the joints if you want to make the bends easier but increase the number of joints.
Harley is offline   Reply With Quote
Old 02-25-2015, 10:19 PM   #25
Got a little more done tonight. Took a few close ups of my not so pretty brazing.
Trying to blend the joints together. Using too much brazing rod to try to cover up my not so precise tube notching.
Got the front stinger bent up. Not sure what the best process would have been on that, but I managed to only totally screw up one piece of rod. Hopefully will get that mounted up tomorrow and then work on figuring out how to mount up the skid.
Old 02-26-2015, 08:07 AM   #26
PSW
Your getting it done Boover, The stinger is one of my favourite bits on this chassis.
Old 02-26-2015, 01:53 PM   #27
Snow day in Alabama so I've made some progress.
Need to just finish up some rear bracing and decide if I want to do some kind of spare mount. Then figure out how to actually tie it in to the skid. Harley's plans have been awesome.
Old 02-26-2015, 02:03 PM   #28
PSW
Nice! Good job Boover.
I can't help you with how to tie it up as I don't know.
Now get it finished & mounted so we can see it in all its glory
Old 02-26-2015, 02:25 PM   #29
20K Club
Harley's Avatar
Mad dog RC has some nice laser cut pieces that line up with a Wraith skid. Otherwise some 16 gauge and a few holes should do it.
Old 03-01-2015, 09:50 PM   #30
I was out of town for the weekend so no real progress. But I did snap a couple shots of the chassis just sitting on the skid. Trying to get my mind turning for how I want to do the shock mounts, rear bracing, and the sliders/boat sides. Really trying to picture how I want the overall look to go from here. Maybe make body panels and try to adapt a JK hood? Hmmm...
Old 03-01-2015, 09:57 PM   #31
Maybe buy a poison spyder wraith body and making panels out of it?
fr8cture is offline   Reply With Quote
Old 03-02-2015, 08:24 AM   #32
20K Club
Harley's Avatar
Great job so far!!
Old 03-02-2015, 08:43 AM   #33
That is definitely one of the options I've been considering, and it is definitely the simplest. Maybe I will buy the body to use the hood and just use the rest as a template to make some aluminum panels.
http://pix.poisonspyder.com/photos/i...-KZbjFck-L.jpg
Or I could go all out and try to make a seperate grill, hood, and fenders like the 1:1. But... that sounds a little ambitious. We shall see.
Old 03-02-2015, 11:58 AM   #34
Originally Posted by Harley View Post
Great job so far!!
Thanks man! I appreciate the encouragement.
Old 03-05-2015, 12:20 PM   #35
Slow progress. I got the skid mocked up.
Now on to shock mounts...
Old 03-05-2015, 07:53 PM   #36
She's a roller!!
It's definitely nowhere close to perfect, but I'm pretty happy with how it came out! Just needs a fair bit of grinding and sanding before paint. My front shock mounts need a little time with the dremel for a little trimming. Right now I'm leaning towards just a poison spyder body, but would love some other suggestions.
Old 03-05-2015, 08:55 PM   #37
20K Club
Harley's Avatar
Looks great man! Nice work.
I really like using .025" aluminum for flat side panels and then throw a seperate hood panel on it.
The Proline Wraith JK body would make a good hood donor also.
Old 03-07-2015, 08:15 PM   #38
The latest challenge is trying to figure out the best way to fit a 5000 mah battery in this thing. I think I've got a decent idea about how to get it done. I think I'll make a large "dash" and have it under that slanted just over the front of the transmission. If that makes any sense...
Old 03-15-2015, 08:51 AM   #39
Battery and electronics tray set in yesterday. Forgot to snag some more pics of it all wired up. But I just mounted the ESC right in front of the battery and put the original receiver box on top of the transmission. Ran it around the yard. Pretty happy with everything! Still running the original Spawn shocks. Need something a tad shorter I think. Extra weight is definitely going to help finish off the motor faster too. I'll have to give HH a call pretty soon.
Now on to fabbing body panels!
Old 03-15-2015, 10:14 AM   #40
PSW
Good Job Boover, Looks great all mounted up.
Any reason for not putting the upside down V bar section in the front windshield area? I think it would look cool. Also any plans to to primer/paint the cage?
Harley Designed Venom Chassis Build - Similar Threads
Class 3 ECSC ---Harley Quinn Build---- Krawler Konceptz 2.2 Scale Rigs 2 08-17-2014 09:21 AM
Venom Creeper Custom tube Chassis build hippo008 General Crawlers 2 07-19-2011 09:08 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
