02-25-2015, 02:23 PM | #1 |
Pebble Pounder Join Date: Nov 2014 Location: in the woods
| Diff gear question
Does anyone know if there is a helical cut ring/pinion set for the AR60 axles' ? Iv seen them for other rc axles and was wondering if there were a set for the wraith? Thanks ahead of time for any input |
02-25-2015, 02:35 PM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Diff gear question
The HD gears from Axial are helical.
02-25-2015, 03:20 PM | #3 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Supershafty.com / RPPHobby.com usually carry them in stock. Could probably get them directly from Axial as well. Look for the Axial Heavy Duty Bevel Gear Sets on supplier's sites, or in your local hobby store. There are three different ratio's available. 36/14 Overdrive 38/13 Stock 43/13 Underdrive |
02-25-2015, 04:12 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
AX30395 - 38/13 - stock ratio AX30401 - 36/14 - higher ratio ("overdrive") AX30402 - 43/13 - lower ratio ("underdrive") Search for those part numbers at Tower, A-Main, e-Bay, Amazon, etc.. You may not find all of them in one place, if you're looking for all three. |
02-25-2015, 06:23 PM | #5 |
RCC Addict Join Date: Jul 2008 Location: San Diego
I'm running the AX30402 - 43/13 -underdrive gears front and rear. If you are running brushless(faster) run the front and rear the same gears. If you are crawling slow you can run the front overdrive in the front and regular in the rear. I would recommend spools front and rear if you are taking them apart. I'm running Locked up rc spools. Holmes Hobbies and super shafty sells them also.
02-26-2015, 03:38 AM | #6 |
Thanks everyone for the comments and help! Guess I should have google'd better. I don't wanna run 2 different gear ratios, I trail to much for that. Guess ill order the stock ratio as I like my wheels speed as it sits, just looking to beef up my drivetrain
Diff gear question - Similar Threads | ||||
Robinson Racing Outdrive diff gear question | Hirschowl | Axial SCX-10 | 11 | 06-09-2014 09:42 AM |
IFS diff gear question | J5races | Axial Wraith | 2 | 05-06-2014 08:43 PM |
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
diff gear | Slipknot23 | Kyosho Crawlers | 6 | 07-26-2005 11:57 PM |
