Thread: Yeti shocks on a wraith
Old 02-25-2015, 10:13 PM   #1
Default Yeti shocks on a wraith
Ok im looking at getting 4 rear yeti shocks to run on my wraith. The Yeti shocks are 125mm vs the stock Wraith 103mm shock. What do you guys think about trying this?
If some one has done this can you post some phots?
My set up is lower shock mounts flipped over,CKRC lowering kit 2.2 Super Swamper sx tires and stock shocks.
greengoblin is offline   Reply With Quote
Old 02-25-2015, 10:31 PM   #2
Default Re: Yeti shocks on a wraith
Try it and let us know how it goes. I'm new and don't know much about different shocks yet, but more even if you're back to stock height with more wheel travel that seems like a good plan.
Boover is offline   Reply With Quote
Old 02-25-2015, 11:04 PM   #3
What springs would you plan on running with them? Aren't the yeti ones more stiff?
Bugglass is offline   Reply With Quote
Old 02-26-2015, 12:45 AM   #4
I like how smooth the rear Yeti shocks feel. The rear yeti shocks are 25mm/1" longer then stock. They have soft rear springs for the Yeti very soft AX31153 0.90 lbs/in Or AX31154 soft 1.01 lbs/in.
SDheavymetal is offline   Reply With Quote
Old 02-26-2015, 09:45 AM   #5
I run the yeti shocks front and rears, they seem to work good for going slow. I just have the collars threaded all the way up so it don't sit as high.
rickrob is offline   Reply With Quote
Old 02-26-2015, 09:48 AM   #6
I can post more if you want
Old 02-26-2015, 10:04 AM   #7
I'm digging those wheels, rickrob!
@greengoblin, I think the Yeti shocks will work well with your lowering kit. I love having low COG, but IMO you could use a bit more belly clearance for crests etc. If they come out too tall, you can limit them internally with some short soft springs and have a good semi-droop setup.
Sent from my 306SH
Philthy is offline   Reply With Quote
Old 02-26-2015, 12:42 PM   #8
Thanks there rc4wd predators I think. They look the same the axial walker Evans, just aluminum and beadlocks.
Old 02-26-2015, 02:33 PM   #9
rickrob Yes post them post away. Thank you
Old 02-26-2015, 05:55 PM   #10
I will tomorrow its packed up for travel.
Old 02-28-2015, 07:38 AM   #11
And a better shot of the wheels
Old 02-28-2015, 11:07 AM   #12
greengoblin- that's where mine sits at ride height with Gtransition shocks set up in full droop and level3 lowering kit. My links too are level with the skid, I love the set up and its only used for rock crawling. The only complaint I have is the break over being that the skids are so low, and I did consider going with the yeti shocks for addition flex. However I'm happy with my 107mm shock lengths, gets the job done for me.
Revoasian is offline   Reply With Quote
Yeti shocks on a wraith - Similar Threads
Yeti shocks leaking DenisLM Newbie General 4 12-16-2014 04:26 PM
