02-28-2015, 09:40 AM | #1 |
Quarry Creeper Join Date: Jul 2014 Location: North Florida.
| Hot Racing Double Up Clutch over kill ?
I was looking up all the slipper clutches that could be used on the wraith and with the Beefy Top shaft Traxxas Slash comes in.. well an upgrade to the Slash is a E Revo slipper.. alot bigger. Well Hot Racing has the double up slipper.. you can now use 6 slipper pads not just 3.. or a T Maxx disk brake pad. I like this over the RRP as you can change the spur gears. Is this E Revo sized slipper over kill with my setup ? HH esc and TQmaster 27t on 3s |
02-28-2015, 09:50 AM | #2 |
| Re: Hot Racing Double Up Clutch over kill ? |
03-04-2015, 12:19 AM | #3 |
Well no one had anything to say so I went with the Slash slipper not the Revo or the Double up slipper. Stock Slash is still alot better than the Axial unit. |
03-04-2015, 03:59 AM | #4 |
RCC Addict Join Date: Feb 2012 Location: UK
I have the Revo Slipper waiting in the wing to go on. It's a beast!
03-04-2015, 08:51 AM | #5 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Don't waste your money. Revo unit or just buy a lockout. Slippers are useless in a Wraith.
03-04-2015, 08:57 AM | #6 |
Well I like to run one.. but the more I beef it up the tighter I can run it. After this round of upgrades the axle shafts themselves are the weak link. I thought about a slipper eliminator but said naw I'll keep one. |
03-04-2015, 09:05 AM | #7 |
I like running slippers. Gives enough cush to keep my driveline a bit happier when I catch air. I like to have the shafts running from axle to tranny as the weak link. They are easy and fast to replace compared to any other parts.
03-04-2015, 09:13 AM | #8 |
Well I will have. Traxxas 32p plastic spur.. Beefy topshaft.. RRP trans gears stock outputs. . Maxx drive shafts. . Mini Loco axle bushings.. Axial HD 43/13 gears. Stock Axial axle shafts. |
03-04-2015, 09:27 AM | #9 | |
| Re: Hot Racing Double Up Clutch over kill ? Quote:
J | |
03-04-2015, 10:52 AM | #10 | |||
Hot Racing Super Duty Light Weight Steel Gear Set SCX10 or Hot Racing standard weight tranny gearset Hot Racing Axial SCX10 AX10 Wraith hard steel center gears set | |||
03-04-2015, 10:59 AM | #11 |
Pebble Pounder Join Date: Mar 2011 Location: Saxonia
slipper's r 4 wimpkinds!
03-04-2015, 11:09 AM | #12 |
I run slippers in anything that goes fast, and lock them down/remove them on anything that goes slow. Shock load seems to do more damage than torque load.
03-04-2015, 11:54 AM | #13 |
And the more hundreds of hours you spend driving various RC's the better you'll get at matching wheel speed with landing speed/angle so that landings take less of a toll. Newbs should run slippers. That last sentence provides a humorous image. J |
03-04-2015, 12:04 PM | #14 |
Slippers are better than crocs...
03-04-2015, 12:26 PM | #15 |
And Crocs are better than wellies. J |
03-06-2015, 10:11 AM | #16 |
Quarry Creeper Join Date: Aug 2014 Location: holland
Thank God no-one mentioned Uggs.... uhm oops. |
03-06-2015, 10:22 AM | #17 |
I was just wanting to keep from killing my axle shafts. And whats wrong with the RRP trans gears ? |
03-06-2015, 11:04 AM | #18 |
RCC Addict Join Date: Aug 2013 Location: Missoula
03-06-2015, 11:07 AM | #19 |
Im not getting the one piece. ..
Hot Racing Double Up Clutch over kill ? - Similar Threads | ||||
Hot Racing Links are hot mess!! | Sethmetal | Axial Wraith | 53 | 04-12-2013 12:27 PM |
Converting To a Robinson Racing Slipper Clutch | tractionaction | Axial SCX-10 | 0 | 06-15-2012 03:56 AM |
Double wave Slipper Clutch | Wetfoot | Axial AX-10 Scorpion | 10 | 06-24-2008 01:07 PM |
