03-09-2015, 04:27 PM | #1 |
Newbie Join Date: Mar 2015 Location: Pell City
| Spawn questions
New guy here so take it easy on me. Bought my son a new spawn this weekend. I intend on running nimh for a while. My question is can someone give me a parts list for upgrades to make it more crawl worthy. Not looking for speed mods. Just the must haves for better crawling. Maybe even add links if you can because since I'm new I might not know what you are talking about without seeing it. By the way I already moved the battery forward. Thanks in advance.
03-09-2015, 04:44 PM | #2 |
Rock Stacker Join Date: Apr 2014 Location: Altoona,Florida
| Re: Spawn questions
Look under "Rock Crawling God" Ren |
03-09-2015, 04:53 PM | #3 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Spawn questions
Can that chart go away now? Gear it down and enjoy it. You will probably find the steering links to be flexy and the servo to be weak. Upgrade as needed. |
03-09-2015, 05:44 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Spawn questions
I see the sheeple chart makes another appearance. As for must haves for crawling, replace the shocks and lower your gearing. Then upgrade the parts that break and make changes based on your specific needs (terrain, driving style, performance needs/wants, etc.). And a little research on specific parts and modifications you're considering wouldn't hurt when you get ready upgrade. |
03-09-2015, 06:40 PM | #5 |
Rock Stacker Join Date: Dec 2014 Location: South of columbus Indiana
| Re: Spawn questions
Gear down, lower CG and get some good tire foams! The rest, replace when it breaks. John |
03-09-2015, 07:04 PM | #6 | |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
| Re: Spawn questions Quote:
I think the same thing everytime I see it. So much there my brain just shuts down and doesn't want to work. I just wanna play with my wraith not read some type of stock chart or the periodic table of wraith nonsense. Must have option parts Got a Spawn RTR - upgrade question Last edited by mrhobby100; 03-09-2015 at 07:10 PM. | |
03-09-2015, 07:32 PM | #7 |
Rock Stacker Join Date: Jan 2015 Location: Alabama
| Re: Spawn questions
I'd focus on durability. On my spawn I've killed the stock servo and my transmission idler gear running on 2s. Still running on the stock steering and suspension links. I rigged up a homemade droop kit and that really helped with the handling. Gearing down on the pinion/spur gear will help with crawling a ton. Lipos will help when you decide to go that route.
03-09-2015, 09:35 PM | #8 |
Newbie Join Date: Feb 2015 Location: Folsom
| Re: Spawn questions
I don't have expert level experience, although I will say, I really enjoyed my Wraith Spawn right out of the box with a little 2S lipo. I thought it was a BLAST and my crawling ability was/is still probably more limited by my poor driving than my Wraith. I highly recommend enjoying the truck out of the box with just moving the battery to the front. That being said, I immediately was unimpressed by the stock steering links and stock shocks.
03-09-2015, 10:30 PM | #9 |
Newbie Join Date: Feb 2015 Location: Hudson
| Re: Spawn questions
I can tell you what i did to the one i have. I changed the 12t pinion to a 10t,moved the battery forward ( lipo 2s 4000mah. 25c) moved the receiver to the rear and the ESC to the front. I also added a Castle BEC. You can also add a metal strip on each side of the frame were the body mount screws are and use Valcro to hold the body on.
03-09-2015, 11:20 PM | #10 |
| Re: Spawn questions
Most of the guys that really use their rigs on a regular basis are 3s. why the hesitation to suggest 3s more power and longer run times with the extra cell of capacity. I have been 3s since I got into the hobby years ago and never looked back at 2s ever. Never burned up an esc or anything.
03-10-2015, 05:55 PM | #11 | |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
Spawn questions - Similar Threads | ||||
New spawn | kenny1219 | Axial Wraith | 6 | 03-29-2015 10:41 AM |
Yet one more spawn | jmercier | Axial Wraith | 1 | 02-19-2015 12:44 AM |
What to do first to the Spawn??? | FortCrawler | Axial Wraith | 16 | 02-13-2015 02:00 PM |
Spawn! | FortCrawler | Axial Wraith | 39 | 02-04-2015 03:35 PM |
Spawn | jlsandkes | Axial Wraith | 2 | 11-17-2014 01:27 PM |
