03-14-2015, 03:39 PM | #1 |
Pebble Pounder Join Date: Jul 2014 Location: Atlanta
| drive pin issue
just about every time I go out I break a drive pin. can anybody help. why am I breaking these so easily? I'll go ahead and say I'm running a 3300kv pro4 but there has to be a solution?
03-14-2015, 04:15 PM | #2 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
| Re: drive pin issue
Sounds like something is binding up. Exactly which pins are breaking? The ones in the drive shafts going to the differentials, or the ones in the axle shafts for the wheel hubs?
03-14-2015, 04:21 PM | #3 |
| Re: drive pin issue |
03-14-2015, 04:31 PM | #4 |
| Re: drive pin issue
Factory pins? And do they fit the axle & hub snugly, or are they loose?
03-14-2015, 05:08 PM | #5 |
Rock Stacker Join Date: Dec 2014 Location: South of columbus Indiana
| Re: drive pin issue
You might look into the VP clamping hex. It holds on the pin AND clamps to the axle. Pretty good setup. John |
03-14-2015, 05:11 PM | #6 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: drive pin issue
I've been using the same hexs and pins going on two years. Stock pins the wraith came with and stock axial locking hexes. What hexes, pins, axles etc are you running? |
03-14-2015, 07:19 PM | #7 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
| Re: drive pin issue
Is this just happening on one wheel, or all of them? If its just one, try moving that hex to a different wheel. If problem follows you got a bad hex, if it stays then you have other problems. If you do need new hex's I would order the DLUX fab cromo hex pins they are much stronger.
03-15-2015, 06:43 AM | #8 |
03-15-2015, 06:55 AM | #9 |
I joined the Band! Join Date: Dec 2014 Location: Earth
03-15-2015, 07:51 AM | #10 |
03-15-2015, 08:10 AM | #11 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: drive pin issue
I'd say the hex or the pins are bad. There must be slop somewhere. Or are the through holes on the shafts damaged?
03-15-2015, 09:03 AM | #12 |
| Re: drive pin issue That's what I'm thinking, there's got to be some movement somewhere. From sloppy pin fit in the axle and/or hex or the wheel nuts could be working loose. I've seen a weak wheel locknuts damage a lot of axles, hex adapters, wheels and pins when they get loose.
03-15-2015, 09:43 AM | #13 |
| Re: drive pin issue
The hex has to loose on the axle. It takes a hammer and pliers to get the axial hex off. It's a pain, but I've never broken a pin. Or the channel in the hex is different? |
03-15-2015, 10:32 AM | #14 |
Pebble Pounder Join Date: Dec 2012 Location: Vancouver
| Re: drive pin issue
Cut down a drill bit that fits in the axle stub. I did that on my slash when I kept shearing the stock pins.
03-15-2015, 11:07 AM | #15 |
| Re: drive pin issue
I'm going to guess it's improper tempering on the pins. They could either be too soft, or are too brittle. Any chance you can take a picture of how they broke? |
03-15-2015, 11:35 AM | #16 |
| Re: drive pin issue
Either chop down some 2mm drills or grab some music/piano wire. Depending on the drill, it may be too brittle though.
03-16-2015, 07:52 PM | #17 |
drive pin issue - Similar Threads | ||||
pin drive wheels ? | lennartchurch | RC4WD Trail Finder 2 | 6 | 03-11-2015 12:59 PM |
New Aluminum wheel hex fits but pin is small issue | Blinkfan5150 | Vaterra Twin Hammers | 9 | 04-12-2013 04:26 PM |
drive pin | 87silverado | Redcat Crawlers | 2 | 12-23-2010 03:29 AM |
Axle drive pin options? | mdowney | Losi Mini-Rock Crawler | 3 | 11-02-2010 05:13 AM |
Drive pin replacements? | teamtom | Tamiya Clod Buster | 8 | 09-01-2007 12:26 PM |
