03-16-2015, 05:16 PM | #1 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
| beef tubes
have a set of beef tubes laying around finally got around to installing them in the front axle. I'm using the stock length screw machine thread of course and ounce i tighten up the c hubs to the axle it binds and won't spin freely. idk whats going on has anyone else had this problem? thanks. |
03-16-2015, 05:37 PM | #2 |
| Re: beef tubes
the screws are a bit too long if you are using the stock plastic c-hubs, I used a flat washer under the screw head until i went with the aluminum vp c-hubs..if you are using aluminum c-hubs already, you can still use a washer or grind a bit off the end of the screw....
03-16-2015, 06:21 PM | #3 |
Pebble Pounder Join Date: Mar 2015 Location: Fairland
| Re: beef tubes
The beef tubes for the waith....are they just inserts or do you have to modify the axle tubes to get them to work? Just wondering since the SCX10 axles actually come apart.
03-16-2015, 06:46 PM | #4 |
| Re: beef tubes
The wraith beeftubes go in the axle tubes...sometimes you have to lightly tap them in...make sure slots line up with the link bracket bolt holes....
beef tubes - Similar Threads | ||||
Beef tubes HELP!!!!! | JAYDEN1999 | Axial AX-10 Scorpion | 7 | 08-19-2014 12:37 PM |
Axle Tubes (Beef Tubes) | Bthomas | Arizona | 12 | 12-04-2013 11:27 AM |
