03-17-2015, 08:37 PM | #1 |
Pebble Pounder Join Date: Feb 2007 Location: Ca 530
| Crawler02's wraith kit with currie axles
I've had my kit for some time now and just finally got it going with a few upgrades I've been needing/wanting for a while now. Here's my parts list so far, Vp currie front axle Vp currie centered rear axle Vp scale knuckles/chubs Vp 10pc titanium links Vp 475 slws Vp cms and panhard mount Hot racing spool (rear) Lockeduprc F.I spool (front) Axial hd gears stock ratio both axles Lockedup rc mini locos bushings instead of bearings for pinions Proline slash powerstrokes (fronts up front an rears on rear) Crawler innovations 6 bolt rims 1" wide Gearhead droop mounts on rear only Exo/yeti radiator in back Supershafty beefy topshaft Robinson racing slash steel spur/slipper 56t 32p Robinson racing pinion 14t 32p Castle MMP Castle bec @7.4v Tekin roc412 3100kv Savox sa1231sg Axial 25t servo horn |
03-17-2015, 09:25 PM | #2 |
Pebble Pounder Join Date: Nov 2014 Location: Danville
| Re: Crawler02's wraith kit with currie axles
Sick. Rockin no roof? Got any better side pics? I dig the decal placement.
03-18-2015, 11:09 PM | #3 |
| Re: Crawler02's wraith kit with currie axles |
04-19-2015, 06:20 PM | #4 |
Well I've got the vp vvd's on the way to see if this beast wants to ad them to its diet of parts it spits out! In the meantime I went ahead and did my version of the wraith fastback mod and took a piece of the back roof section and was able to ad it in as a windshield spreader bar because I've broken the cage once already in that area. Let me know what you guys think! I'm going to put the roof panel back on now after I trim it to fit and I'd like to sleeve the pieces of all thread I used for the back of the cage with some brake line. |
04-20-2015, 08:35 PM | #5 |
Rock Stacker Join Date: Feb 2010 Location: Phoenix
Looking good. |
04-24-2015, 06:08 PM | #6 |
04-24-2015, 07:21 PM | #7 |
Rock Stacker Join Date: Mar 2012 Location: SoCal
...been toying with the idea of the /\ windshield piece leftover from the fastback mod... You executed it nicely! Could you pass on some advice for how to securely attach it (especially the top of the /\ to the upper windshield bar). Or a close up pic of attachment points? ...much appreciated!
04-24-2015, 07:51 PM | #8 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Really looks aggressive done up like that. I like it |
04-24-2015, 09:47 PM | #9 | |
| Re: Crawler02's wraith kit with currie axles Quote:
Thank you sir | |
04-24-2015, 11:49 PM | #10 |
Thanks! ...my mind was thinking along the same lines,albeit much slower!... your ride rocks!
04-28-2015, 12:49 PM | #11 |
Well I kept breaking the gearhead droop mounts I was using in the rear so I got rid of them completely and swapped the slash rears onto the front an the fronts to the rear. Much better setup imo with the vp cms/ph and other than that been beating on this thing daily with no problems yet Last edited by crawler02; 04-28-2015 at 12:53 PM. |
04-29-2015, 05:10 PM | #12 |
05-01-2015, 01:38 PM | #13 |
Crawler02's wraith kit with currie axles - Similar Threads | ||||
Wraith Vanquish Currie Axles | twistedjeep | Axial Wraith | 2 | 09-02-2013 07:48 AM |
VP wraith width Currie axles | xgerstandtx | Axial Wraith | 3 | 03-01-2013 07:38 PM |
