02-04-2016, 06:53 AM | #81 | |
Newbie Join Date: Feb 2013 Location: windsor
02-04-2016, 11:22 AM | #82 | |
Quarry Creeper Join Date: Jun 2011 Location: panama city
| Re: Tummy Tuck Quote:
Sent from my SCH-S968C using Tapatalk | |
03-03-2016, 07:54 PM | #83 |
Rock Stacker Join Date: Jan 2016 Location: Houston
| Re: Tummy Tuck
Welp I found a solution...throw money at it. Had EmeryworX make some new lower rails for me. Was a bit of a fight to get them in since they have zero flex, but the result was worth it. Last edited by FaustKnight; 03-03-2016 at 08:02 PM. |
03-03-2016, 08:27 PM | #84 | |
03-03-2016, 08:30 PM | #85 |
Quarry Creeper Join Date: Dec 2014 Location: Tulsa
| Re: Tummy Tuck
I saw those rails. $75 is more then I wanted to spend. So I got a little creative tonight. I have no idea if it will work, but what the hell. Rails were already broken. I shaved down the rails to fit inside some 1/4 brake line. Drilled some new holes and I'll shoegoo tomorrow(thanks for the tip Poprivet). Hopefully it'll hold for awhile. |
03-03-2016, 09:07 PM | #86 | |
Yeah they were a bit pricey, but pre-drilled and tapped and a really good fit made it worth it to me. Not to mention they're not aluminum (DOM). They fit in well with my plan to slowly build a full metal chassis. Ran em a bit tonight for a test and I can climb much taller ledges than I could before. Also lowered my cg a bit and stiffened my chassis a LOT. | |
03-03-2016, 09:11 PM | #87 | |
03-03-2016, 11:24 PM | #88 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
| Re: Tummy Tuck
What about a metal pipe shaved in half, or a plate for the screws to go through? All these are going with scx10 axles right, no ar60s?
03-04-2016, 04:58 AM | #89 |
| Re: Tummy Tuck |
05-08-2017, 09:10 PM | #90 |
Rock Stacker Join Date: Jul 2013 Location: North West CT
| Re: Tummy Tuck
I know this thread's a year old, but whatever. Been back and forth for a week or so on whether or not to do this to my 2.2 Wraith. Got a few in the tank tonight and went for it. I wish I knew how to post pics. Anyway, it was pretty easy. I had to ditch the spur gear cover and slide the skid/suspension/axles back about 1/2" to clear my front-mounted battery. I view this as a positive anyway to move the weight of the truck further forward. Also had to clearance the receiver box crossmember (factory spawn location) to clear the servo now that it sits a little further back and had to clearance the front of the skid to clear the driveshaft. Very small amount. Rear was fine. I am very happy with the results. Actually looks more scale. Only tested in the garage so far. Hopefully I get a chance to test tomorrow. The truck will now clear two 2x4s stacked with a 75% droop setup at ride height.
05-17-2017, 03:34 PM | #91 |
Rock Stacker Join Date: Apr 2012 Location: zeeland
| Re: Tummy Tuck
Here was my solution for strengthening the chassis after doing a tummy tuck. I used some 1/4" plywood aluminum channel and drilled through it. Works great and almost acts as a rock slider too. |
05-17-2017, 04:54 PM | #92 |
| Re: Tummy Tuck
When I did my tummy tuck I made sure that I made my screw holes for the plate large enough for the screws to slip through easily then I touched the top of where the screws would go in flatten the edge of the rail just enough so the screws set flat I've had no pinching of that and no breakage and I've had my tummy tuck for a year Sent from my SCH-I545 using Tapatalk |
05-17-2017, 06:23 PM | #93 |
Rock Stacker Join Date: Apr 2017 Location: Carlisle
| Re: Tummy Tuck
I'm fairly new to battery RC's in general let alone Wraiths, I'm a converted Nitro runner. I picked up the spawn kit a few weeks ago and I love it. I'm seriously considering doing this mod, but here's my question... is it an ok mod to do running a factory setup with the 2.2s? Second question... would i need any additional parts to make everything work after the mods. My spawn is pretty much a factory kit setup with the Axial 55T motor and a crappy servo that i am looking to upgrade soon. Thanks in advance for the help.
05-17-2017, 06:25 PM | #94 |
| Re: Tummy Tuck
Fairly easy. Good with stock setup. No addition as l parts needed. Sent from my SCH-I545 using Tapatalk |
05-17-2017, 06:34 PM | #95 |
| Re: Tummy Tuck
Awesome, thanks for the fast reply. I might copy MaxxCrawl's idea and use some 1/4 inch C channel to give a bit more strength.
05-17-2017, 06:36 PM | #96 |
| Re: Tummy Tuck
That was a nice idea. Dual purpose strength and rock sliders Sent from my SCH-I545 using Tapatalk |
05-23-2017, 06:22 PM | #97 |
| Re: Tummy Tuck
I really thought long and hard, I want my clearance and sliders too. Wertymade WM03 stinger and sliders together. I can always use nose weight, this will add a bit, but more stiffness from the front to the rails Hang up and Drive |
06-06-2017, 03:56 PM | #98 |
| Re: Tummy Tuck
I finally got around to doing mine. I posted the pics on my rigs thread. "Blue" another new guy with a spawn |
03-23-2021, 08:21 AM | #99 |
Pebble Pounder Join Date: Mar 2021 Location: Clinton
| Re: Tummy Tuck
Recently purchased a Wraith Spawn, and consequently have been drawn to this forum as I have researched tons of tips/tricks and hacks for this platform. I am interested in doing this mod for clearance but it is not clear to me from just pictures what it is that I need to do. Can someone please explain to me where to start? |
03-29-2021, 01:36 AM | #100 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Tummy Tuck
Tummy tuck requires you take your 2 lower frame rails, cut off the bottom hoop & re-drill at least 2 holes back into the rail above it (doesn't need all 4 on each side) Whilst it will increase clearance, if you don't make some other changes as well it will effect your link geometry, not necessarily for the better. The tummy tuck also raises the the trans & motor in the chassis, raising the overall Center of Gravity (CoG) making it more inclined to roll over. The counter to this is softer springs & lower ride height, somewhat negating the clearance gain under the skid in the first place. Last edited by altd896; 03-29-2021 at 11:15 PM. |
Tummy Tuck - Similar Threads | ||||
Tummy Tuck HELP! | Deezul | General Crawlers | 4 | 05-14-2006 09:44 PM |
tummy tuck | jeep511 | General Crawlers | 2 | 04-14-2006 08:10 AM |
my tummy tuck | Derek | General Crawlers | 8 | 02-22-2006 06:47 PM |
Another tummy tuck | scout21972 | General Crawlers | 16 | 02-02-2006 01:36 PM |
