Thread: Tummy Tuck
Old 03-29-2021, 12:29 PM   #101
Default Re: Tummy Tuck
Originally Posted by altd896 View Post
Tummy tuck requires you take your 2 lower frame rails, cut off the bottom hoop & re-drill at least 2 holes back into the rail above it (doesn't need all 4 on each side)
Whilst it will increase clearance if you don't make some other changes as well it will effect your link geometry, not necessarily for the better.
The tummy tuck also raises the the trans & motor in the chassis, raising the overall Center of Gravity (CoG) making it more inclined to roll over.
The counter to this is softer springs & lower ride height, somewhat negating the clearance gain under the skid in the first place.
Thank you for the response. Seems like an easy mod, however I was hoping to keep the same height not increase it by raising motor and trans.
I would prefer to lower COG but still do the tummy. Guess I can't have my cake and eat it too
Den72 is offline   Reply With Quote
Old 03-29-2021, 11:22 PM   #102
Using some lowering tabs, like these https://www.rpphobby.com/product_p/gea1218.htm
to raise the upper shock mounts on the chassis will lower the chassis & CoG, but reduce belly clearance ..... that is where you gain some back in the tummy tuck.
You can also lower the CoG with weight in/on the axles/knuckle/wheels
altd896 is offline   Reply With Quote
Old 04-28-2021, 08:43 AM   #103
tuner's Avatar
I have some tummy tuck rails ready to ship. If anybody’s interested pm me on Facebook. EmeryworX fabrication.
tuner is offline   Reply With Quote
Tummy Tuck - Similar Threads
Tummy Tuck HELP! Deezul General Crawlers 4 05-14-2006 09:44 PM
tummy tuck jeep511 General Crawlers 2 04-14-2006 08:10 AM
my tummy tuck Derek General Crawlers 8 02-22-2006 06:47 PM
Another tummy tuck scout21972 General Crawlers 16 02-02-2006 01:36 PM
