03-23-2015, 09:39 AM | #1 |
Rock Stacker Join Date: Jan 2015 Location: Burlington, ON, Canada
| Fasteddybearings vs Wraith kit bearings
If I'm building a kit Wraith is it worth ordering bearings from Fasteddy and use them instead, or are the ones on the kit good quality?
03-23-2015, 09:53 AM | #2 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Re: Fasteddybearings vs Wraith kit bearings
I found that Fasteddy bearing are better oiled than stock bearings, but if your going to change them, change them for something like ceramics.....or maybe fully ceramics.
03-23-2015, 10:01 AM | #3 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
Go with fasr eddies if any! No need for payin outrageous price of ceramic on a trail type rig. |
03-23-2015, 10:03 AM | #4 |
RCC Addict Join Date: Feb 2012 Location: UK
I'd use the ones in the kit first. They are good quality.
03-23-2015, 10:09 AM | #5 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Kit bearings are good, but it would be wise to order the Fast eddy bearings as well for spares.
03-23-2015, 10:23 AM | #6 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
I'm still using the majority of the bearings that came stock with my wraith after over a year. I don't drive in water or mud so that has a lot to do with it. The ones I did replace we're because I happened to rebuild the front axle and threw the cheap RPP bearing in my cart. Cheap bearings are good if you don't drive in nasty stuff.
03-23-2015, 12:36 PM | #7 |
OK, thanks for all the advise guys. I'll order some Fasteddy bearings to have as spares, and use the kit ones for now (it's mostly all built, so no point ripping it apart to replace them now).
10-15-2015, 08:20 AM | #8 | |
Quarry Creeper Join Date: Aug 2007 Location: El Dorado Hills Ca
| Re: Fasteddybearings vs Wraith kit bearings Quote:
If your building the kit, use our bearings in your build and save the stock for spares. Less chance of needing to replace them as quickly. Remember to support the companies that support this site and the crawler / scale hobby. See you at the next event. FastEddyBearings Ball bearings & RC Bearing kits -Ed | |
Fasteddybearings vs Wraith kit bearings - Similar Threads | ||||
NEW Axial AR60 Axle Sealed Bearing Kit FastEddyBearings.com | FastEddy | General Crawlers | 1 | 09-13-2013 07:51 AM |
Axial Wraith Ceramic Sealed Bearing Kit **New Release** FastEddybearings.com | FastEddy | Axial Wraith | 3 | 09-13-2013 07:48 AM |
Twin Hammers Bearing Kit FastEddyBearings.com | FastEddy | Vaterra Twin Hammers | 11 | 03-18-2013 09:50 AM |
6X11X4 Bearings NOW AVAILABLE from FastEddyBearings.com | FastEddy | General Crawlers | 0 | 07-23-2012 09:50 AM |
