03-25-2015, 03:10 PM | #1 |
Newbie Join Date: Mar 2015 Location: Houston
| 32p gear question
S o I got a 32p spur and pinion, but I also ordered a set of HD gears for the trans I did not think about the 32p. Am I correct in that I will need to find 32p trans gears? I haven't seen any in my looking around, if someone could point me in the right direction I would really appreciate it.
03-25-2015, 03:23 PM | #2 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: 32p gear question
The 48 pitch HD transmission gears are fine.
03-25-2015, 03:48 PM | #3 |
Ok sweet! that makes me feel a little less like I am screwing up this build.
03-25-2015, 06:44 PM | #4 |
Pebble Pounder Join Date: Mar 2015 Location: Fairland
Why would 48 Pitch gears be a problem? I would think that you would get more contact area from 48 Pitch gears. I know 32p have a bigger bite but you get less teeth that are biting so to speak.
03-25-2015, 07:45 PM | #5 |
It's gearing 101, larger teeth are simply stronger. The 48 pitch teeth are about half the height of 32, and since (one or both) gears are round you have about two teeth from each (drive/driven, pinion/spur) engaged at the same time. If you have much more than that engaged you get gears than bind. You don't get more teeth in the mesh with 48, or MOD 0.5 or 64, you actually get less because the teeth are smaller. This is why 48 pitch strip easier. The reason our internal transmission gears last a little longer than the spur is because they're about twice the width and there's less deflection in the transmission. So the gears stay closer together a little better. |
03-25-2015, 09:07 PM | #6 |
That makes sense to me. Thanks for clearing that up for me. Always like learning something new! So would you say that hardened steel gears are a lifetime replacement for the most part or will they too eventually need to be replaced?
03-25-2015, 10:23 PM | #7 |
The HD gears will eventually wear out like the plastic, but it will take much longer and you're less likely to randomly break teeth off them. They're certainly a durability and longevity upgrade.
03-25-2015, 10:30 PM | #8 | |
Rock Stacker Join Date: Jan 2008 Location: Tehachapi
| Re: 32p gear question Quote:
PS I'm 70 with major medical problems. Ar,ar,ar,ar,ar,ar, yeah, I know-----SIC! Just had to say it. Ron | |
03-26-2015, 06:34 AM | #9 | |
Quarry Creeper Join Date: Feb 2006 Location: Muskegon
1:! gears are the same way, even staying the same pitch. lower (numerically higher) gear ratios are inherently weaker. I.E. a 4.56 ratio is weaker than a 3.08. That's why for more common rear ends, like the Ford 9" they make weird ratios, like 4.57. 4.56 = 41/9 teeth 4.57 = 32/7 teeth the 4.57 is stronger, because each individual tooth is larger. | |
03-26-2015, 07:22 AM | #10 |
RCC Addict Join Date: Feb 2012 Location: UK
I used to get called 32p teeth at school. :( Haha.
32p gear question - Similar Threads | ||||
32p Gear matches? | Skizurp | Axial Wraith | 13 | 05-31-2014 07:49 AM |
32p gear mesh question | jeepscx10 | General Crawlers | 3 | 04-12-2013 11:47 AM |
Switching to 32p gear help | throttlejock27 | Axial Wraith | 23 | 03-26-2013 09:22 PM |
How to Reduce 32P Gear Noise | 5.2LJeep | Axial Wraith | 12 | 01-17-2012 11:36 AM |
