03-26-2015, 09:16 AM | #1 |
Rock Stacker Join Date: Jan 2015 Location: Burlington, ON, Canada
| Is the one steel gear in the trans OK?
I want to change out the two stock plastic gears in the transmission with metal ones, but the Hot Racing set of three metal gears is sold out from many places and RPP Hobby says about three weeks to get new stock. I can get the RR metal ones, but only the bottom gear and idler gear which would mean using the stock metal gear from Axial. So I guess my question is, should I wait for new stock on the Hot Racing gear set, or just go with the two from RR and keep the stock Axial one? Has any one had problems with the stock Axial metal gear in the transmission? |
03-26-2015, 09:58 AM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Is the one steel gear in the trans OK?
Stock top gear is good to go I've broken 2 RRP lower gears, still on the Axial top gear. Last edited by maslin; 03-26-2015 at 10:03 AM. |
03-26-2015, 10:01 AM | #3 | |
| Re: Is the one steel gear in the trans OK? Quote:
03-26-2015, 10:31 AM | #4 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
It depends on how much power you are running. The stock top gear isn't bulletproof but will last a while under moderate power levels. I ended up trashing one in a heavy rig with lots of pro4 power. The HR 3 gear set has been great for me.
03-26-2015, 12:27 PM | #5 |
Thanks for all the advice guys... I'm using a HH Trailmaster with 3S, but mostly find myself crawling and trail running, so no real bashing. Guess running it like that, the top gear should be good for some time. |
03-26-2015, 12:52 PM | #6 |
Either the hot racing gears or the Axial aftermarket ones are good choices. If you don't drive too recklessly the plastic gears will last quite a long time.
03-27-2015, 12:39 AM | #7 |
Pebble Pounder Join Date: Nov 2014 Location: Danville
I am running that gear stock still with the plastic ones upgraded to steel. No problems here, and I beat it pretty hard, low speed though.
Is the one steel gear in the trans OK? - Similar Threads | ||||
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Steel XR Gear set? | morpheus_tn | Axial XR10 | 3 | 03-05-2012 10:47 AM |
Steel drive gear for WK | SnoopMaxx | HPI Wheely King | 16 | 04-16-2008 06:53 AM |
