03-28-2015, 10:01 AM | #1 |
Newbie Join Date: Mar 2015 Location: Soda City
| Stubby's Build
New to the forum and thought I'd share my Wraith build as it progresses from stock. Started off with a Poison Spyder Wraith Deans Plugs Added an aluminum servo horn (picked up from local hobby shop for cheap) Vanquish chubs, knuckles, steering linkage, four link set coming Wed/Thursday. Next step: "waterproofing" axle shafts, driveshafts, tires/wheels Last night I did a custom battery relocation using the stock parts. Moved the ESC to the rear, relocated on/off switch for easier access. I think it turned out pretty well. Started by removing the interior, upper cage and necessary body parts to access the internals. Secured ESC to the rear battery box using zip ties. Waterproofing and better installment to come. This is just temporary. Secured the battery to the front using existing straps from battery tray Used scotch tape to put over the existing mount, cut out holes and put the tape where I wanted the on/off switch to be. Turned out pretty good. And some fun pictures some are before and after the battery mod. |
03-28-2015, 10:09 AM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Stubby's Build
Cut the on off switch and solder the wires. Saves a headache down the road
03-28-2015, 02:38 PM | #3 |
| Re: Stubby's Build |
03-28-2015, 03:39 PM | #4 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
| Re: Stubby's Build
Yeah its not needed at all
03-29-2015, 01:04 PM | #5 |
Pebble Pounder Join Date: Nov 2014 Location: Danville
| Re: Stubby's Build
Yea better to unplug the battery. If you end up getting a BEC in the future you will have to anyway. I ended up using the stock switch for lights Last edited by thirdeye; 03-29-2015 at 05:56 PM. |
Stubby's Build - Similar Threads | ||||
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) | Irishchamp | 2.2 Scale Rigs | 45 | 10-09-2014 10:26 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
