Simple Wraith Lighting Question Hello All: I have searched many a thread and just trying to find a simple answer but must be looking in all the wrong places.... Running the RTR Poison Spyder...and I just purchased the axial 5 bucket light kit and the axial simple led controller and the 5 led light string. I'll be sticking with the stock AR-3 reciever. I have the BEC in the BAT slot and the CH3 slot is empty. Here is the simple question......Can I just plug the led controller into CH3 and "let there be light"? Not planning on running more lighting than the 5 bucket and tail lights. Much Appreciated. |
Re: Simple Wraith Lighting Question That is how I run mine. |
Re: Simple Wraith Lighting Question Yup, you did it right. Most people will use the next available channel 3 or 4, if that's not available you could use a servo y harness. BEC does go into battery or another available channel, just make sure you de-pin or cut the red power wire from the ESC before plugging into channel 2. |
