04-02-2015, 06:31 PM | #1 |
Rock Stacker Join Date: Jan 2015 Location: Burlington, ON, Canada
| What's the largest spur gear that will fit?
I currently have a 56/10 32p gearing in my Wraith, and would like to try a larger spur gear to see if I can get it crawl slower (using a HH trailmaster on 3S, runs great, just want to see how slow I can get it when I'm running it on rocks). What is the largest spur that will fit in the tranny where I can still fit the cover on?
04-02-2015, 07:01 PM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: What's the largest spur gear that will fit?
56T is about the largest and still get the cover on. Maybe try a 9T pinion, although I run a 56/11 in my Wraith with a Crawlmaster Pro 16T and it does just fine at low speed. Could be just the difference in motors.
04-02-2015, 07:23 PM | #3 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
I run a 58x10 be creative... you can make anything (almost) fit |
04-02-2015, 07:33 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
You can get a 58 tooth under the gear cover, but it's a tight fit and may rub the cover if the cover is warped a little. A 60 or higher will require the cover to be removed and then you start hitting the drive shaft yoke. I think Robinson Racing has 9 tooth pinions if you need something lower than 58/10. You can also lower the axle gears with the 43/13 gear set in both axles if needed.
04-02-2015, 07:51 PM | #5 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Pfft.. you just want to see if you can make it pull your 1:1 :p ...video when you do. xD |
04-02-2015, 08:01 PM | #6 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
A little secret...... tune your throttle exponential to around -75
04-03-2015, 02:28 AM | #7 |
Thanks for all the great advice... |
04-03-2015, 07:10 AM | #8 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Ditch the cover, 64 fits with the wraith mip output.
04-03-2015, 09:41 AM | #9 |
| Re: What's the largest spur gear that will fit? That's what I've been trying to tell her, for years! (Sorry, no technical help) I ran the Trailmaster on 4s in my wraith. 56/11 and 54/13, and most options between.. I'm still running on in my scx. 56/11 on 4s.. I really enjoy the way the motor's performs. I may be dropping to 56/10 for this season. The more has more then enough torque and great startup. I'm just going to be trying the same as you. A touch smoother for the slow slow crawl. |
What's the largest spur gear that will fit? - Similar Threads | ||||
whats the largest 32p spur that will fit? | skybolt | Axial Wraith | 5 | 12-02-2014 07:35 AM |
Largest spur gear? | Chris333 | Losi Micro-Rock Crawler | 4 | 02-02-2012 03:34 AM |
Wraith Spur gear Cover.. Won't fit my SCX10 | madkawi650 | Axial AX-10 Scorpion | 2 | 09-24-2011 05:12 AM |
largest spur gear | base shakers | Axial SCX-10 | 0 | 02-10-2010 05:07 PM |
Will this spur gear fit? | red4x4 | Axial AX-10 Scorpion | 12 | 02-03-2009 12:19 AM |
