Thread: Slash shocks
Old 04-03-2015, 10:14 PM   #1
Default Slash shocks
Thinking about getting the slash 104mm shocks as recommended somewhere on here...
Is there any additional hardware needed to mount them on a spawn and what weight oil should I start with for mainly rock crawling?
Cammmo is offline   Reply With Quote
Old 04-04-2015, 06:58 AM   #2
Default Re: Slash shocks
Oil will depend on you preference and weight of your rig. Only real help I can be is suggest Dollarhobbyz for when ever you are buying stock parts. I just bought a set of the savage 160mm for the rear. Way over sized but work great after a little tuning and softening the springs, for $15 it was worth it. I have a full summit and stampede minus electronics and trays for parts in the garage for the other trucks for $65 So the kid and wife don't have to order parts.
mike31 is offline   Reply With Quote
Old 04-04-2015, 09:26 AM   #3
If you're looking at the powerstrokes....
You probably going to need the spring kits as well, they're pretty stiff out of the box. They make a universal mounting kit, or nitro fuel line and some screws.
I run 20wt in the rear, 30wt in the front.
maslin is offline   Reply With Quote
Old 04-04-2015, 11:39 AM   #4
For mounting my Traxxas Big Bores on my Wraith I used the shock ends made by DLUX.
They look great and saved me from migivering something to get them to pivot/move at the top without binding.
flyboy320 is offline   Reply With Quote
Old 04-04-2015, 01:02 PM   #5
DLUX shock ends. I run my Bigbores with Axial purple springs, regular pistons and 30wt. The shocks have a firm damping and feeling with this setup, much firmer than stock Axial shocks. I really like this setup.
Odd-M is offline   Reply With Quote
Slash shocks - Similar Threads
King S.C. Slash shocks or proline slash shocks for wraith??? axial 4x4 crawler Axial Wraith 38 07-11-2014 05:47 PM
