04-10-2015, 07:20 PM | #1 |
Rock Stacker Join Date: Feb 2010 Location: Phoenix
| U4RC Wraith Build
Well in between racing/wrenching 3 short course trucks with my boys and a crazy work/family schedule, I've decided to get back into the shop and work on my U4RC Wraith based truck. This all started with too much YouTube time, some mockup AR60's axles and a wraith chassis I had laying around from other projects. This build will not have many factory parts when she is done. The power train is still being debated but I am leaning toward a Tekin ROC412 with Mamba Max Pro on 3s LiPo. I got the first batch of parts today from the brown truck and were starting with the VP titanium full link kit, VP knuckles, c hubs and lockouts, Fast Eddy bearing kit, Axial CVDs (VP is out of stock), MIP drive lines and VP Method wheels. Tires are still undecided but I have some PS BFG's for mockup. Chassis will be modified with a DMG stiffy kit. Thoughts and suggestions are always welcome.
04-11-2015, 10:31 AM | #2 |
| Re: U4RC Wraith Build
Made some progress last night on the build. Installed the complete Fast Eddy bearing kit, Vanquish knuckles, chubs, lockouts and Axial CVDs. To beef up the tranny I am going with the Robinson Racing hardened one piece diff and idler gear, which are on their way. A top shaft and one piece motor plate from Super Shafty are also getting ordered. I am looking for suggestions for a good aluminum tranny case. Here are some in progress photos. More to come soon.
04-11-2015, 10:48 AM | #3 |
Build pics.
04-14-2015, 08:40 PM | #4 |
Not adding any photos this time since everything keeps coming in upside down. I am still waiting on tranny parts. Bit the bullet and ordered the front VP Currie axle and VP chassis servo mount. The VP Currie rear axle will be ordered soon. For tires I have decided on the Voodoo U4's. Electronics will be ordered soon. Completed the battery relocation and hood mods (PS Jeep hood for now). Shocks are undecided but I am running some Losi CC's for now.
04-16-2015, 05:04 AM | #5 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Not to sound negative, because I love VP stuff, the Curries are just too much of a pain to work on if you have to. I would have went with the VP AR60 housings if you wanted metal ones. Also don't think you will like the CMS. It tends to push the chassis instead of turning the wheels. But a great build none the less.
04-16-2015, 05:58 AM | #6 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
Lol damn upside down pictures, smart phone didn't tell me if I changed hands the pics came out right. |
04-16-2015, 10:45 PM | #7 |
Thanks for the comments. I installed the CMS today but am not going 3 link panhard. I can see how it would cause bumpsteer, so we'll see if that stays. Installed the Robinson Racing hardened gears in the tranny today. Just ordered the Mamba Max Pro ESC, Tekin Roc412 3100kv motor and Castle 10a BEC. Still waiting on other parts. I am considering a whole new U4RC chassis that accepts the wraith drivetrain. I don't think a stock chassis will last more than a few outings based on the way I race. Pics will be coming soon.
04-16-2015, 10:50 PM | #8 |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
a cms not installed correctly with all the intended parts is going to cause adverse conditions. The setup actually works well the way it was intended to be setup. Its pretty much the exact copy of a real version.
04-16-2015, 10:54 PM | #9 | |
| Re: U4RC Wraith Build Quote:
it only pushes the chassis if you don't use the panhard bar. Its there for a reason connects the chassis and axle and keeps them at a set distance from eachother thru the suspension cycle. Trust me I build offroad trucks you gotta set suspension up the way its meant to be if you mess with it and just remove parts here and there its not gonna work and you will get frustrated. Every body who had an issue with the cms not working properly either was missing a piece or didn't line stuff up correctly. youwant the steering link and the panhard bar to be at as close of the same angle as possible or when the suspension cycles it will bind and push things outta wack. | |
04-16-2015, 11:12 PM | #10 |
Thanks guys. I will go ahead and order the pan hard. I really like the servo being tucked up in the chassis. Its looks awesome and will help keep my servo from slamming into rocks. Here are some updated photos that are not upside down. Nothing too detailed because I was not taking pics while working today but I will post more as the build progresses.
04-17-2015, 12:04 AM | #11 |
I see teeth marks on yur rod ends. Some people are claiming they are breaking rod ends easily on the revo stuff recently. Instead of using pliers which might stress the part where its thin. Place the ball on a table and then push the rod end down onto the ball with your fingers. You wont mark up the rod ends or stress the plastic as much that way and I have never broken a rod end yet and I crashed hard a few times this last weekend. Broke servos right off the axle broke a vvd and the same rod ends are still going.
04-17-2015, 03:47 PM | #12 |
Some more goodies just showed up. Gotta love Amazon 1 day free shipping. Still waiting on the Roc412, Currie axle and some other stuff.
04-17-2015, 03:48 PM | #13 | |
04-17-2015, 04:42 PM | #14 |
Pebble Pounder Join Date: Feb 2007 Location: Ca 530
Awesome start I'll be watching this for sure it looks like your going the same direction I have gone with my wraith |
04-17-2015, 08:20 PM | #15 | |
Newbie Join Date: Feb 2012 Location: Ramona, Kali.
04-18-2015, 09:59 AM | #16 |
A little more progress. Got the BEC and battery connecter soldered up. Decided to make it easier for programming and ordered the Holmes Hobbies Bypass Adapter for the BEC. Ordered the VP pan hard as well. After some fitting I was able to get everything under the hood with a hard case LiPo. All the wires will fit neatly as well. Can't go any further until parts show up next week. The brown truck feels like a blessing and a curse some times. The bummer is we have U4RC racing going on right down the road today and I am staring at a pile of parts.
04-19-2015, 12:40 AM | #17 |
Completed some chassis work. The fastback supports are metal for extra strength. This body is just for mockup. I will be using the hood and repainting it once I get some aluminum skins. Just another step closer to U4RC racing.
04-20-2015, 01:14 AM | #18 |
I could not stand the blue any longer. So I got a little paint work done. This is by no means my best paint work but it will do for now.
04-20-2015, 07:33 PM | #19 |
Got some more goodies today.
04-21-2015, 08:43 PM | #20 |
Time to solder up some new connectors. I am also going to work on fitting the electronics for the final time.
U4RC Wraith Build - Similar Threads | ||||
Darkstar's U4RC Tuber Build | darkstar | Axial Wraith | 57 | 05-18-2015 10:27 AM |
mallcrawler's U4RC IBEX build | mallcrawler24 | 2.2 Scale Rigs | 22 | 01-15-2015 06:00 AM |
The Abomidable YETI U4RC Build.... | scottanthony | Axial Yeti | 22 | 08-02-2014 03:49 PM |
U4RC/KOH Build Stage 1 | Tourettic1 | Axial Wraith | 7 | 06-01-2014 12:08 AM |
Basket case Wraith roller to U4RC 2.2 rig. Another anti-IFS Wraith. | 89redranger | Axial Wraith | 7 | 03-30-2014 08:24 PM |
