04-11-2015, 04:17 PM | #1 |
Newbie Join Date: Apr 2015 Location: Norfolk, UK
| First Wraith kit build..
I will soon be building my first Axial (Wraith kit) with a Xcelorin 21.5T motor/esc combo and I would like a recommendation for gearing and battery choice please.. I need good scale crawling ability and runtime, I'm not at all interested in a high top speed.. Cheers, Buzz. Last edited by Mad Zero; 04-12-2015 at 05:14 AM. |
04-12-2015, 08:43 AM | #2 |
| Re: First Wraith kit build..
Forgot to mention.. my sister is really hot and I could get pics of her in the shower.. Sent from my iPad using Tapatalk |
04-12-2015, 09:00 AM | #3 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Well you're in luck, because we accept bribes! Shoot for a 5:1 ratio on gearing, if not a little higher. As for battery a 2s 5000mah battery should put you in the range you're looking for. |
04-12-2015, 09:03 AM | #4 |
Pebble Pounder Join Date: Jul 2007 Location: Reedsburg
I run stock spur and a 15 tooth 48 pitch pinion or a 11 tooth 32pitch pinion on a 56 tooth spur also 32 pitch
04-12-2015, 09:07 AM | #5 |
Newbie Join Date: Jan 2015 Location: lacey
| Re: First Wraith kit build.. I bought these for just over 30 dollars a piece. Heard nothing but great reviews on them and the battery lasted longer than my driveline last week end and when I went to go store it, they were not even 25 % gone after a couple hours. Great for the price. Good luck on your kit build. |
04-12-2015, 01:11 PM | #6 |
Cheers guys I'll see what I get in the kit and re-pinion/spur accordingly.. As for the build it will be pretty stock to start with (I will add wheel weights) until I see where improvements can be made. I have experience of building Clod, TLT and Scout based crawlers but this is my first Axial and I'm new to LiPo also as I'm still quite well stocked with NiMH so I have a bit to learn.. quite exciting really! |
04-18-2015, 12:26 PM | #7 |
| Re: First Wraith kit build.. |
04-18-2015, 01:48 PM | #8 |
Rock Stacker Join Date: Jan 2015 Location: Boone
Just file the motor mount. A dremel would work nicely.
04-18-2015, 02:01 PM | #9 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
Nope, you will have to go bigger on the spur gear unfortunately. Even if you massage the holes on the motor plate a little bigger to get it to work, the motor will hit the transmission case and still not allow for proper gear mesh. Sorry bro! The upside is you will have much better lower gearing for crawling like you wanted too with a larger spur gear with that 15t pinion. I run a 88/15 with mine HR aluminum spur gear, and it puts me at 5.8 ratio, just perfect for my driving style on the rocks. If you really want to keep the 80t spur gear than get the 18t pinion and maybe you will be ok without modding the motor plate hole, proper gear mesh is a must.
Last edited by Revoasian; 04-18-2015 at 02:10 PM. Reason: Added additional information |
04-18-2015, 07:16 PM | #10 | |
| Re: First Wraith kit build.. Quote:
First Wraith kit build.. - Similar Threads | ||||
My first kit wraith build | Spence700 | Axial Wraith | 4 | 01-16-2013 02:42 PM |
Wraith kit build | Dslzuk91 | Axial Wraith | 21 | 01-03-2013 11:44 AM |
Wraith Kit Build!! --My first | flyingrc | Axial Wraith | 31 | 04-05-2012 09:56 AM |
My wraith kit build - something different... | Dneff13 | Axial Wraith | 0 | 01-03-2012 08:48 PM |
Wraith Kit build NEEDS... | Natedog | Axial Wraith | 10 | 12-23-2011 02:28 PM |
