04-18-2015, 07:44 AM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: Florida Gulf coast
| Body and cage mod advice needed
I have my Wraith kit on its way to me from RPP and I am wondering if anyone has mounted non Wraith bodies to their rigs? I've only seen a few but one that looked cool was a Jeep G6 with its own cage. How are they doing that? I've also seen folks using EXO body/cage combos on Wraiths. I'm just looking for something different and not the same cookie cutter cage layout.
04-18-2015, 10:26 AM | #2 |
Rock Stacker Join Date: Feb 2010 Location: Phoenix
| Re: Body and cage mod advice needed
The wrexo mod is usually done to get independent front suspension and is an expensive endeavor requiring basically 2 complete vehicles. There a lot of bodies made specifically for the Wraith that will change its look. There are some vendors on here like DMG that make partial cages that bolt in and change the whole look. There is the simple and cheap fastback mod as well.
04-18-2015, 10:59 AM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
The G6 body (& I've seen the deadbolt done too) is mounted by chopping off all the stock roll cage & mounting to body over it. The chassis must flex something horrible on the ones I've seen pics of because the never rebraced it front to back to compensate for loosing the roof cage. The G6 jeep body is externally the same as the Poison spider body, so either it or the deadbolt could have the cockpit cut out & they'd drop right over the wraith cage. I chopped out the C pillar & the gussets at the top rear of the B pillar, heated the roof section with a normal electric heat gun & pulled it down. Fixed with a couple of screws to the rear upper shock mount. |
04-19-2015, 10:03 AM | #4 | |
| Re: Body and cage mod advice needed Quote:
04-19-2015, 10:47 AM | #5 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Essentially the core of the Wraith is the skid, trans, and axles. Anything that'll mount to the skid can act as a body. Really is pretty versatile.
Body and cage mod advice needed - Similar Threads | ||||
Cage mod... how to... | DrDiff952 | Axial Wraith | 3 | 06-27-2013 10:34 PM |
cage mod | snohiker | Axial Wraith | 51 | 06-18-2013 11:58 PM |
Advice needed to save my body | mud digger | Paint and Body | 5 | 07-27-2012 03:02 PM |
Cage mod help? | o0wiz0o | Axial Wraith | 27 | 06-27-2012 09:31 PM |
Body building advice needed | spacephrawg | General Crawlers | 9 | 07-04-2010 06:52 PM |
