04-20-2015, 07:19 PM | #1 |
Newbie Join Date: Mar 2015 Location: Speingfield
| Best 120mm shock for the wraith
What would you guys suggest for shocks ATM im running stock ones with a lowering kit
04-20-2015, 07:29 PM | #2 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
| Re: Best 120mm shock for the wraith
If they came in 120mm, I would say pro-line powerstrokes. I am not sure what lengths the traxxas shocks come in but I have had decent luck with the big bore shocks. Cheers, Wade |
04-20-2015, 07:38 PM | #3 |
Newbie Join Date: Dec 2014 Location: columbus
| Re: Best 120mm shock for the wraith Yeti rears are 125. You can get them to 123 with changing the lower ball end. |
04-21-2015, 07:09 PM | #4 |
Newbie Join Date: Dec 2014 Location: Sydney
I've used the Yeti shaft, body and spring with the rest of the wraith shock parts to make shocks.
04-21-2015, 08:46 PM | #5 |
Newbie Join Date: Feb 2015 Location: duluth
I like the hot racing ones. Some of them are internal spring which makes it look sort of scale like an air shock, and i have those in the 120mm and theyre really nice, they have 3 different spring setups too! Soft, medium, firm
Best 120mm shock for the wraith - Similar Threads | ||||
120mm shock suggestions? | yzf128r | General Crawlers | 2 | 03-17-2010 08:03 PM |
?? Actual length of CKRC 120mm Threaded Aluminum Shock | LoveToROCK | Axial AX-10 Scorpion | 2 | 10-10-2008 05:42 PM |
**New 120mm Shock Ax-10 Replacement** | run2jeepn | Chassis and Suspension | 12 | 08-04-2008 06:08 PM |
Would 120mm shock work with a diaz design chassis? | NewCrawler82 | Newbie General | 6 | 12-22-2007 08:51 AM |
