04-30-2015, 01:15 PM | #1 |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
| 4ws and rear sway bar ??
Anyone running both? Contemplating removing some of the rear bed, and relocating sway bar mounts. Anyone have any good pics of how to fit it all in there ?
04-30-2015, 02:38 PM | #2 |
| Re: 4ws and rear sway bar ??
I'm sure it will fit but probably rub.
04-30-2015, 03:39 PM | #3 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
All you'd be doing is mirroring the stock front swaybar / steering setup. Shouldn't rub unless your mount relocation puts it in the way of the shocks.
04-30-2015, 05:58 PM | #4 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
Looking at my stock rsb flipping the mount forward would cause it to interfere with the shock. If you could fab a longer bar it would clear but at that point there would be a fair amount of flex at the ends making it less effective. Maybe some bar stock and mounts farther out would work.
04-30-2015, 07:44 PM | #5 |
Pebble Pounder Join Date: May 2013 Location: kinzers
ive done the same thing with mine my servo horn on the rear servo hits the sway bar if I push down on the back I only lose 1/8 or less of travel never seen it hit when crawling my setup is taller then most like them i use the med bar it seems to help get traction in some situations that i didn't before i may try the weakest bar next if this one doesn't weaken a little it seems a bit to stiff for me overall i do recommend putting it in rear heres my thread with some pics hope it helps unlimited wraith budget |
05-01-2015, 08:13 AM | #6 |
Thanks y'all!!
4ws and rear sway bar ?? - Similar Threads | ||||
rear sway bar | Sc91gt | Axial Yeti | 7 | 02-22-2015 08:33 PM |
Rear sway bar | Cchapman | Axial Yeti | 2 | 12-30-2014 11:18 PM |
Rear sway bar! | sixshooterstang | Axial Yeti XL | 3 | 11-14-2014 12:26 PM |
Dlux sway bar on a 4ws wraith | rknaub | Axial Wraith | 4 | 06-22-2014 10:22 PM |
