05-05-2015, 11:54 AM | #1 |
Quarry Creeper Join Date: Mar 2014 Location: san antonio
| Question regarding upper links
So I picked up a Wraith on trade last week and it came with Integy or Cappu junk aluminum upper and lower links. I want to swap them out with a set of home made links but I have questions about the uppers. Does it matter at all if I don't bend the uppers and leave them straight? I don't have a tube bender and I don't really want to just eyeball it so can I leave the uppers straight? Sorry if there is already info out there on tis subject, I tried searching but was unsucessful. Appreciate any help guys. |
05-05-2015, 12:04 PM | #2 |
| Re: Question regarding upper links
First thing to go was the back half of the cage. Quickly got tired of the stock body so this happened. Still need to straighten out the lines but I'm happy with it. Just need to toss those junk links now. Sent from my iPhone using Tapatalk |
05-05-2015, 12:09 PM | #3 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
You could use a vise to bend them, I've done it many times before. I'm fairly sure they need a bend to clear the driveshafts.
05-05-2015, 12:10 PM | #4 |
Technically it doesn't matter if a link is straight or shaped like a curly straw. Whether a straight link clears everything or not, I do not know. You can eyeball bend em over a counter top or in a vise or whatever. A hammer handle. Literally anything. Bolt two together and start leaning on em and they bend pretty easy.
05-05-2015, 12:10 PM | #5 |
| Re: Question regarding upper links |
05-05-2015, 12:19 PM | #6 | |
| Re: Question regarding upper links Quote:
Thanks EeePee. I'll try that. So you're saying run a bolt and nut through both ends to keep them "square" right? try to get as close a possible equal bend in them that way? Last edited by jason02ws6; 05-05-2015 at 12:23 PM. | |
05-05-2015, 12:29 PM | #7 |
I joined the Band! Join Date: Dec 2014 Location: Earth
You'll need at least one bent link on the front and rear. Straight links on the driver's side will cross paths with the drive shafts when the suspension is compressed.
05-05-2015, 12:32 PM | #8 |
05-05-2015, 12:39 PM | #9 |
Yes that's what I'm saying. Or a little imporised jig. Very simple stuff, don't be deterred. Realize links get shorter when you bend them. |
05-05-2015, 12:53 PM | #10 |
| Re: Question regarding upper links That's exactly what I was thinking. My plan is to measure from eye to bend on each half of the link and make a straight link that size, then bend it until I get to where I need to be. Thanks for looking out though.
05-05-2015, 12:56 PM | #11 |
My initial thought was to make my own lowers and just paint the uppers black, but there is a terribly ridiculous amount of slop in the upers. They flop around all over the place and it's just plain not good.
05-05-2015, 02:26 PM | #12 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
The upper by the driveshafts need to be bent or you will probably bind against the shaft. I love my vp titanium upper links |
05-06-2015, 05:48 PM | #13 |
Rock Stacker Join Date: Jan 2012 Location: Vancouver
I made some aluminum uppers and used only hand tools for the bends. I marked with link with a line where the bend needed to be, sandwiched it between a rock and a hard place so that the line was level with the edge of the hard edged object and hammered the link until the bend achieved the eye to eye distance i needed. Hope this helps.
05-06-2015, 08:27 PM | #14 |
Thanks for the tips RMack. I'll try that and see what results I get. Sent from my iPhone using Tapatalk |
05-08-2015, 09:26 PM | #15 |
I found a super cheap tube bender at Harbor Freight today and put in some work. Pretty happy with the end result. In case anyone is in the market here's the info on the bender I picked up. Sent from my iPhone using Tapatalk |
05-20-2015, 09:46 AM | #16 |
Newbie Join Date: Jun 2013 Location: Burlington
I made my own from stainless steel. I will measure the length I used once i'm home. they were the same as the uppers, used a 10/24 die and put on some traxxas revo rod ends. for the bend...i just used a vise and bent them to match the stock ones. It's a 15 degree bend.
05-20-2015, 09:51 AM | #17 | |
I went a little overboard with my bends. They are in between 30-45 degrees but they are all matched and work so I'm good with it. I'm going to put a small bend in the lowers as well for a little more clearance. i used plain old brake tubing and all thread for mine, it's what I could find cheap and in stock. At some point I'd like to step up to stainless tubing but I'm having a little trouble finding any in my area. | |
05-20-2015, 10:44 AM | #18 |
Newbie Join Date: Apr 2009 Location: right here
What size Stainless tubing do you need? We have some here at the shop. Like 1/4" OD? travis |
05-20-2015, 11:16 AM | #19 |
05-20-2015, 11:33 AM | #20 |
I don't use the tube style. Just rod for added strength. Next is the steering linkage but i have no idea how long to make the drag link and tie rod. 171mm is still too short. Need a Vp one to copy from
Question regarding upper links - Similar Threads | ||||
Using upper links for bottom links? I've hit a dead end! | TIME MACHINE | Axial AX10 2nd-gen | 2 | 03-04-2015 11:00 PM |
DIY upper links question | flyboy320 | Axial Wraith | 10 | 02-10-2015 11:40 AM |
Vanquish Upper Links Question | casepuller | Axial Wraith | 1 | 03-02-2012 09:51 PM |
Question about upper/lower links... | the02stangman | Newbie General | 2 | 06-25-2009 06:09 PM |
