05-11-2015, 04:23 PM | #1 |
Rock Stacker Join Date: May 2010 Location: middletown
| wraith bodies
I was gonna buy a spawn...do all the other bodies regular wraith and poison bolt right up are there holes on the spawn to screw the top on..sry noobie
05-11-2015, 06:08 PM | #2 |
Newbie Join Date: Dec 2013 Location: Mentor
| Re: wraith bodies
Yes the other bodies and panels will work, its the same chassis. The spawn comes with new versions of parts that the wraith rtr doesn't, water tight box, wb shafts, dual slipper, bead locks. And its cheaper.
05-14-2015, 09:10 AM | #3 |
Quarry Creeper Join Date: Jul 2011 Location: Temecula
| Re: wraith bodies
And the spawn has a different interior, more of a "half" interior. Not sure if the old style panels will work with this because of the 'V' at the door area. It might leave a void between the panels and the interior. But I've never seen the new interior first hand, so I don't know for sure. I found this pic. Looks like it might work, maybe just a little space below the bottom of the interior. It doesn't go down all the way to the 'V' in the cage. It would be easy to fix that though with a little heat. Last edited by snicklefritz; 05-14-2015 at 09:24 AM. |
05-14-2015, 07:39 PM | #4 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: wraith bodies
Stock replacement panel set doesn't come trimmed, it would be easy to cut the top edge of the panel straight like a closed door instead of having the V out of it.
wraith bodies - Similar Threads | ||||
Wraith bodies? What bodies are you running? | AXLE 69 | Axial Wraith | 29 | 09-25-2014 01:17 PM |
Wraith bodies ~ We need more Wraith bodies!! | SwampDawg | Axial Wraith | 24 | 08-15-2012 07:26 AM |
A few Wraith bodies | caci623 | Paint and Body | 11 | 02-28-2012 07:33 AM |
